jQuery UI Widgets Forums General Discussions Editors DateTimeInput DateTimeInput problem in IE
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 12 years ago.
  • DateTimeInput problem in IE #24558
    Snehal
    I have set date format in format string
    $(“#dateTimeInput”).jqxDateTimeInput({ width: ‘235px’, height: ’25px’, theme: theme, formatString: ‘dd-MMM-yyyy HH:mm’ });
    and i returned date object with:
    $(“#dateTimeInput”).jqxDateTimeInput(‘getDate’);
    It is giving me correct date in firefox , in the format which i require
    ” Date {Fri Jul 05 2013 12:31:00 GMT+0530 (India Standard Time)} ”
    but for the same in IE it returns date in this format :
    ” Fri Jul 5 12:31:00 UTC+0530 2013 ”
    Why it is returning the different values for the same object in firefox and IE?
    please tell me how will i get the date in this ( ” Date {Fri Jul 05 2013 12:31:00 GMT+0530 (India Standard Time)} ”  )format in IE also?
    Thanks & Regards,
    Snehal
    DateTimeInput problem in IE #24566
    getDate() returns a JavaScript Date object, not a String and the implementation of toString() implementation of a JavaScript Date object is not necessary to be the same in the different browsers. You can learn more about the JavaScript Date Object here: http://www.w3schools.com/jsref/jsref_obj_date.asp. If you want to get the displayed String from the input, use getText() method instead.
