jQuery UI Widgets Forums Grid Date filter does not work after a resize
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 9 years, 2 months ago.
  • Vaccano
    I have a grid that is auto sized to fix to my window. This grid also has a Date Time column with a filter range on it.
    Initially the filter works fine. But if I re-size the window, then try to use the range filter, it will not show (at least not in chrome). It flashes on the screen for a split second (at the wrong spot) and is then gone.
    I have removed that filter row from my application, so I this is not something you want to fix, I don’t really care. I just thought I would report it to be a good community member.
    Hello Vaccano,
    Thank you for the feedback.
    Is it possible to use some older version?
    I would like to ask you for some example if it is possible.
