jQuery UI Widgets Forums Chart Data Series Order (stacking) and Legend Order
This topic contains 3 replies, has 2 voices, and was last updated by  DXC13 5 years, 8 months ago.
  • DXC13
    Is there a way to either have a custom order for the legend or set the z-index of each data series display?
    I have a chart with 3 data series (splinearea, column, and spline) … splinearea needs to be in the background behind the other lines and bars but appear last in the legend.
    From back to front: splinearea (A), column (B), spline (C)
    Legend order: B,C,A
    To put the splinearea in the background I assign that series first to the group but that also puts it first in the legend. So I can either add the data in display order and change the legend or in legend order and change the display but I haven’t found a way to either change legend order or display order without changing the order in which I add the series.
    Any help would be appreciated … Thanks!
    Hello DXC13,
    The series are displayed in order that they are in the seriesGroups” property.
    Unfortunately, there is no suitable option to change the order.
    Could you clarify it if I do not understand you?
    Also, could you provide your example where the order of the series does not have a matter on the display.
    I tested this example and it seems to work fine:
    https://www.jqwidgets.com/jquery-widgets-demo/demos/jqxchart/javascript_chart_axis_position.htm?arctic
    As an alternative I would like to suggest you create a custom legend and show/hide series via methods.
    DXC13
    Here is an example
    https://jsfiddle.net/gkqL29m0/
    I need SeriesD to be in the background of the chart (as in the example) but I also need it to be listed last in the legend.
    The way I see it there are 2 options. Reorder the legend … which sounds like that is not possible at this time. Or be able to push the SeriesD graphic to the background (sort of assigning a z-index or render order)
    I may have to see if I can manipulate the DOM on refresh.
    DXC13
    Manipulating the DOM does seem to work
    https://jsfiddle.net/2tu83dnf/
    Apply the series in Legend order then move the DOM section to the top of the parent.
    var target = $(“path[stroke=’#229954′]”);
    var container = $(“path[stroke=’#229954′]”).parent();
    $(container).prepend(target);
    The only requirement is being able to select the correct <path> but in this case since all the colors are known I could select it by the stroke color.
    Works with animation also.
