jQuery UI Widgets Forums Grid Data missing after adding code
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 13 years, 4 months ago.
  • Data missing after adding code #2858
    rondc
    I am using your example for Building CRUD Web App with jqxGrid. Everything seem to work fine up to the point when I add the code for the button click events. Once I add this code, then run the script nothing is displayed. But if I remove this code the data shows in the grid just fine. Here’s my code:
    var theme = ‘classic’;
    { name: ‘ID’},
    { name: ‘Student Name’},
    { name: ‘ACT-SAT’},
    { name: ‘GPA’},
    { name: ‘TRANSFER GPA’},
    { name: ‘BIOL100’},
    { name: ‘MATH101-111’},
    { name: ‘HPED’},
    { name: ‘UNST110’},
    { name: ‘NURS100’},
    { name: ‘UNST120’},
    { name: ‘UNST130’},
    { name: ‘CHEM104’},
    { name: ‘UNST140’},
    { name: ‘CHEM114’},
    { name: ‘FCS310’},
    { name: ‘STATISTICS’},
    { name: ‘BIOL220’},
    { name: ‘BIOL361’},
    { name: ‘PSYC320’},
    { name: ‘UNST Elective 1’},
    { name: ‘UNST Elective 2’},
    { name: ‘NURS300’},
    { name: ‘NURS310’},
    { name: ‘NURS320’},
    { name: ‘NURS350’},
    { name: ‘NURS351’},
    { name: ‘FCS337’},
    { name: ‘NURS414’},
    { name: ‘NURS400’},
    { name: ‘PSYC434’},
    { name: ‘NURS405’},
    { name: ‘UNST CLUSTER 1’},
    { name: ‘UNST CLUSTER 2’},
    { name: ‘NURS412’},
    { name: ‘NURS416’},
    { name: ‘NURS418’},
    { name: ‘NURS500’},
    { name: ‘NURS510’},
    { name: ‘NURS513’},
    { name: ‘NURS514’},
    { name: ‘NURS518’},
    { name: ‘NURS520’},
    { name: ‘NURS524’},
    url: ‘data.php’,
    addrow: function (rowid, rowdata) {
    // synchronize with the server – send insert command
    var data = “insert=true&” + $.param(rowdata);
    dataType: ‘json’,
    url: ‘data.php’,
    data: data,
    deleterow: function (rowid) {
    // synchronize with the server – send delete command
    var data = “delete=true&ID=” + rowid;
    dataType: ‘json’,
    url: ‘data.php’,
    data: data,
    // delete command is executed.
    var data = “update=true&” + $.param(rowdata);
    dataType: ‘json’,
    url: ‘data.php’,
    data: data,
    root: ‘Rows’,
    var dataadapter = new $.jqx.dataAdapter(source);
    // initialize jqxGrid
    $(“#jqxgrid”).jqxGrid(
    width: 2200,
    source: dataadapter,
    pagesize: 25,
    virtualmode: true,
    selectionmode: ‘singlerow’,
    rendergridrows: function()
    return dataadapter.records;
    { text: ‘Student Name’, datafield: ‘Student Name’, width: 250 },
    { text: ‘ACT-SAT’, datafield: ‘ACT-SAT’, width: 50 },
    { text: ‘GPA’, datafield: ‘GPA’, width: 50 },
    { text: ‘TRANSFER GPA’, datafield: ‘TRANSFER GPA’, width: 110 },
    { text: ‘BIOL100’, datafield: ‘BIOL100’, width: 62 },
    { text: ‘MATH101-111’, datafield: ‘MATH101-111’, width: 100 },
    { text: ‘HPED’, datafield: ‘HPED’, width: 75 },
    { text: ‘UNST110’, datafield: ‘UNST110’, width: 65 },
    { text: ‘NURS100’, datafield: ‘NURS100’, width: 65 },
    { text: ‘UNST120’, datafield: ‘UNST120’, width: 65 },
    { text: ‘UNST130’, datafield: ‘UNST130’, width: 65 },
    { text: ‘CHEM104’, datafield: ‘CHEM104’, width: 65 },
    { text: ‘UNST140’, datafield: ‘UNST140’, width: 65 },
    { text: ‘CHEM114’, datafield: ‘CHEM114’, width: 65 },
    { text: ‘FCS310’, datafield: ‘FCS310’, width: 65 },
    { text: ‘STATISTICS’, datafield: ‘STATISTICS’, width: 100 },
    { text: ‘BIOL220’, datafield: ‘BIOL220’, width: 65 },
    { text: ‘BIOL361’, datafield: ‘BIOL361’, width: 65 },
    { text: ‘PSYC320’, datafield: ‘PSYC320’, width: 65 },
    { text: ‘UNST Elective 1’, datafield: ‘UNST Elective 1’, width: 100 },
    { text: ‘UNST Elective 2’, datafield: ‘UNST Elective 2’, width: 100 },
    { text: ‘NURS300’, datafield: ‘NURS300’, width: 65 },
    { text: ‘NURS310’, datafield: ‘NURS310’, width: 65 },
    { text: ‘NURS320’, datafield: ‘NURS320’, width: 65 },
    { text: ‘NURS350’, datafield: ‘NURS350’, width: 65 },
    { text: ‘NURS351’, datafield: ‘NURS351’, width: 65 },
    { text: ‘FCS337’, datafield: ‘FCS337’, width: 65 },
    { text: ‘NURS414’, datafield: ‘NURS414’, width: 65 },
    { text: ‘NURS400’, datafield: ‘NURS400’, width: 65 },
    { text: ‘PSYC434’, datafield: ‘PSYC434’, width: 65 },
    { text: ‘NURS405’, datafield: ‘NURS405’, width: 65 },
    { text: ‘UNST CLUSTER 1’, datafield: ‘UNST CLUSTER 1’, width: 100 },
    { text: ‘UNST CLUSTER 2’, datafield: ‘UNST CLUSTER 2’, width: 100 },
    { text: ‘NURS412’, datafield: ‘NURS412’, width: 65 },
    { text: ‘NURS416’, datafield: ‘NURS416’, width: 65 },
    { text: ‘NURS418’, datafield: ‘NURS418’, width: 65 },
    { text: ‘NURS500’, datafield: ‘NURS500’, width: 65 },
    { text: ‘NURS510’, datafield: ‘NURS510’, width: 65 },
    { text: ‘NURS513’, datafield: ‘NURS513’, width: 65 },
    { text: ‘NURS514’, datafield: ‘NURS514’, width: 65 },
    { text: ‘NURS518’, datafield: ‘NURS518’, width: 65 },
    { text: ‘NURS520’, datafield: ‘NURS520’, width: 65 },
    { text: ‘NURS524’, datafield: ‘NURS524’, width: 65 }
    // trying to add click event code here.
    Thanks. Any thoughts.
    Data missing after adding code #2859
    Hi rondc,
    1. Could you paste the full script + html code here? You can format the code by using the “Format HTML Code” button which is situated before the Red Text color button. In addition, all examples of the Grid are also included in the installation package with the full source code. You can find them in the ‘php_demos’ folder.
    2. There’s also a ‘,’ which is not necessary after the:
    { name: ‘NURS524’},
    Looking forward to your reply.
