jQuery UI Widgets › Forums › Chart › Custom tool tips and other issues
This topic contains 7 replies, has 4 voices, and was last updated by Peter Stoev 12 years, 12 months ago.
I would like to change the “tool tips” that show when I hover over a point on my line, scatter, and area graphs. I was looking at the API and don’t see any functionality for this. Is this possible?
When I hover over a section of a line in a line graph a point shows up with a tool tip. Is there any way to have these points always show? Right now not all my points will come up when I’m hovering over the line.
One final thing I noticed even on the demo chart is that the tool tip “flashes” like it is constantly being turned off and on when you hover over a point on the line. Is there a way to stop this behavior so the tool tip stays active as long as a user is on the point?
MillisaHi Millisa,
– The points are displayed only on hover. We will consider adding the requested functionality as an option in a future version.
– There’s still no option for customizing the tooltip’s display behavior. They delay is 4 seconds. After that, the displayed tooltip is hidden. Your suggestion makes sense and we will add an option for that behavior, too.Thank you for the feedback!
Best Wishes,
http://www.jqwidgets.comPeter,
When I run the code below I have and issue seeing the points for all the lines. The top lines are fine. But as you go down the points no longer show up. I’m not sure if I’m doing something wrong or if this is a bug.
Millisa
var data = {
"series": [{"displayText": "1","dataField": "1"},
{"displayText": "2","dataField": "2"},
{"displayText": "3","dataField": "3"},
{"displayText": "4","dataField": "4"},
{"displayText": "5","dataField": "5"},
{"displayText": "6","dataField": "6"},
{"displayText": "7","dataField": "7"},
{"displayText": "8","dataField": "8"},
{"displayText": "9","dataField": "9"},
{"displayText": "10","dataField": "10"},
{"displayText": "11","dataField": "11"},
{"displayText": "12","dataField": "12"}
"odds": [
{"label": "Cycle 0 3:04:50PM","1": 7.41,"2": 3.07,"3": 0.0,"4": 38.9,"5": 4.5,"6": 0.0,"7": 0.82,"8": 7.01,"9": 9.22,"10": 22.73,"11": 5.38,"12": 0.91},
{"label": "Cycle 1 3:04:02PM","1": 7.56,"2": 2.94,"3": 0.0,"4": 34.16,"5": 4.75,"6": 0.0,"7": 0.77,"8": 6.57,"9": 9.36,"10": 26.32,"11": 6.35,"12": 1.17},
{"label": "Cycle 2 3:03:31PM","1": 7.38,"2": 3.02,"3": 0.0,"4": 28.96,"5": 4.23,"6": 0.0,"7": 0.94,"8": 6.34,"9": 10.0,"10": 31.36,"11": 6.44,"12": 1.28},
{"label": "Cycle 3 3:03:02PM","1": 8.34,"2": 3.7,"3": 0.0,"4": 27.56,"5": 5.61,"6": 0.0,"7": 1.68,"8": 9.29,"9": 10.81,"10": 24.12,"11": 6.83,"12": 2.02},
{"label": "Cycle 4 3:02:31PM","1": 9.09,"2": 3.71,"3": 0.0,"4": 19.88,"5": 6.95,"6": 0.0,"7": 1.88,"8": 11.21,"9": 10.07,"10": 28.02,"11": 6.62,"12": 2.51},
{"label": "Cycle 5 3:02:02PM","1": 8.67,"2": 4.01,"3": 0.0,"4": 20.32,"5": 7.35,"6": 0.0,"7": 1.99,"8": 10.39,"9": 10.16,"10": 27.51,"11": 6.77,"12": 2.77},
{"label": "Cycle 6 3:01:31PM","1": 8.93,"2": 4.23,"3": 0.0,"4": 20.1,"5": 7.73,"6": 0.0,"7": 2.02,"8": 10.05,"9": 10.39,"10": 26.89,"11": 6.79,"12": 2.81}
"maxValue": 40
}var settings = {
title: "Cyclical Odds",
showLegend: true,
padding: { left: 5, top: 5, right: 11, bottom: 5 },
background: 'transparent',
borderColor: 'transparent',
source: data.odds,
categoryAxis:
dataField: 'label',
showTickMarks: true,
showGridLines: true
colorScheme: 'scheme01',
seriesGroups:
type: 'line',
valueAxis:
unitInterval: 2,
minValue: 0,
maxValue: data.maxValue,
displayValueAxis: true,
description: '% of Net Win pool',
axisSize: 'auto'
series: data.series
};$('#jqxLineChart').jqxChart(settings);
I am unable to reproduce that, I am able to show the points for the bottom lines and the lines above them. In my test, I tried the SVG and VML rendering of the chart and used jQWidgets 2.1. However, I will continue investigating the reported behavior. Thank you!
Best Wishes,
http://www.jqwidgets.comCustomizing chart tooltips would be a great future enhancement. I have the need to do so as well.
Hi robrichard,
Actually Tooltips formatting is included in the today’s release – jQWidgets 2.2.1.
Best Wishes,
http://www.jqwidgets.comIs it possible to add a newline in the tooltip?
Hi thalyric,
Tooltips Text Wrapping is still not supported.
Best Wishes,
