jQuery UI Widgets › Forums › Grid › Custom Selection not working for me
This topic contains 5 replies, has 3 voices, and was last updated by hadaad 12 years, 4 months ago.
I have a grid with checkbox in first column and I am follow your example custom Selection. But when make property editable: true then before grid populating showing Please add reference to the following modules : jqxgrid.edit.js . But I already have this script reference and the other all script reference require to populate grid. Please help me in urgent.
Hi basumrinmoy,
In case you did not added the required files, a message will pop up by design. There is no issue with that behavior. In addition, in the custom row selection sample, the Grid is already editable.
http://www.jqwidgets.comThank you for your reply.But I have added all require files . But i use the free version or non commercial version. Is there any problem for using free version? I can’t find any problem from my side . Please help me how i can find checkbox column in grid and select any row using checkbox.
Hi basumrinmoy,
I suggest you to download the working sample and use it as a start. I also suggest you to take a look at the help documentation available online. If the required files are not included, the Grid will not be displayed. This is not related to which version you have downloaded.
http://www.jqwidgets.comI’m having the same issue that basumrinmoy is/was having.
I have a clear reference to jqwidgets/jqxgrid.selection and I have an alert popping up on my screen to include jqxgrid.selection.js.HTML:
[code]<!DOCTYPE html>
<html>
<link rel=”stylesheet” href=”../script/jqwidgets/styles/jqx.base.css” type=”text/css”/>
<link rel=”stylesheet” href=”../script/jqwidgets/styles/jqx.classic.css” type=”text/css”/>
<script type=”text/javascript” src=”../script/scripts/jquery-1.8.2.min.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxcore.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxbuttons.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxscrollbar.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxlistbox.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxdropdownlist.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxmenu.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxgrid.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxdata.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxgrid.pager.js”></script>
<script type=”text/javascript” src=”../script/jqwidgets/jqxgrid.sort.js”></script>
<script type=”text=javascript” src=”../script/jqwidgets/jqxgrid.selection.js”></script>
<title>Test JQuery grid with JQWidgets</title>
<body>
$(document).ready(function () { // prepare the data
var data = new Array();
var firstNames = [ “Andrew”,
“Nancy”,
“Shelley”,
“Regina”,
“Yoshi”,
“Antoni”,
“Mayumi”,
“Ian”,
“Peter”,
“Lars”,
“Petra”,
“Martin”,
“Sven”,
“Elio”,
“Beate”,
“Cheryl”,
“Michael”,
“Guylene”
var lastNames = [
“Fuller”,
“Davolio”,
“Burke”,
“Murphy”,
“Nagase”,
“Saavedra”,
“Ohno”,
“Devling”,
“Wilson”,
“Peterson”,
“Winkler”,
“Bein”,
“Petersen”,
“Rossi”,
“Vileid”,
“Saylor”,
“Bjorn”,
“Nodier”
var productNames = [
“Black Tea”,
“Green Tea”,
“Caffe Espresso”,
“Doubleshot Espresso”,
“Caffe Latte”,
“White Chocolate Mocha”,
“Cramel Latte”,
“Caffe Americano”,
“Cappuccino”,
“Espresso Truffle”,
“Espresso con Panna”,
“Peppermint Mocha Twist”
var priceValues = [
“2.25”,
“1.5”,
“3.0”,
“3.3”,
“4.5”,
“3.6”,
“3.8”,
“2.5”,
“5.0”,
“1.75”,
“3.25”,
“4.0”
];for (var i = 0; i < 100; i++) {
var row = {};
row["price"] = price;
row["quantity"] = quantity;
data[i] = row;
}var source1 = { data: data, datatype: "array" };
$("#Grid").jqxGrid({
width: 670,
source: source1,
theme: 'classic',
text: 'First Name',
datafield: 'firstname',
width: 100
text: 'Last Name',
datafield: 'lastname',
width: 100
text: 'Product',
datafield: 'productname',
width: 180
text: 'Quantity',
datafield: 'quantity',
width: 80,
cellsalign: 'right'
text: 'Unit Price',
datafield: 'price',
width: 90,
cellsalign: 'right',
cellsformat: 'c2'
text: 'Total',
datafield: 'total',
cellsformat: 'c2'
</script><div id="Grid"></div>
</html>[/code]
Found the solution to my problem. Typographical error: text=javascript instead of text/javascript. My bad.
