jQuery UI Widgets Forums Grid createfilterwidget in column level filtering
This topic contains 16 replies, has 4 voices, and was last updated by  Peter Stoev 10 years, 6 months ago.
Viewing 15 posts - 1 through 15 (of 17 total)
  • arunthatham
    Hi All,
    I need the equivalent of createfilterwidget at the column level. Right now i’m able to do createfilterwidget only if i have showfilterrow:true. I need the same functionality to be done for the date picker in the filter which supports conditions and operators (And, Or, less_than,greater_than etc). Please advice.
    Hello arunthatham,
    You can see how to modify the filter menu in the demo Filter Conditions.
    arunthatham
    thanks dimitar. You saved a lot of time. I have one more issue. I select the date in the datepicker as dd/mm/yyyy but after i apply filter it is changed to mm/dd/yyyy. I’m not sure why it is getting changed
    Hi arunthatham,
    Please share how you implemented your modification so that we may tell you if there is anything wrong with it.
    arunthatham
    updatefilterpanel: function () {
    if ($(“.jqx-datetimeinput”).length > 0) {
    $(“.jqx-datetimeinput”).jqxDateTimeInput({ formatString: ‘dd/MM/yyyy’ });
    I select ’10/08/2014′(10th Aug 2014) and click on filter. After i get the records and i again open the filter i see ’08/10/2014′(8th Oct 2014) being selected.
    Hi arunthatham,
    Your code is not correct. Here is a working example:
        <script type="text/javascript" src="../../jqwidgets/globalization/globalize.js"></script>
                var data = generatedata(500);
                    localdata: data,
                    datafields:
                        { name: 'date', type: 'date' },
                        { name: 'price', type: 'number' }
                    datatype: "array"
                var addfilter = function () {
                    var filter_or_operator = 1;
                    var filtervalue = 'Beate';
                    var filtercondition = 'contains';
                    var filter1 = filtergroup.createfilter('stringfilter', filtervalue, filtercondition);
                    filtervalue = 'Andrew';
                    filtercondition = 'starts_with';
                    var filter2 = filtergroup.createfilter('stringfilter', filtervalue, filtercondition);
                    filtergroup.addfilter(filter_or_operator, filter2);
                    // add the filters.
                    $("#jqxgrid").jqxGrid('addfilter', 'firstname', filtergroup);
                    // apply the filters.
                    $("#jqxgrid").jqxGrid('applyfilters');
                    width: 850,
                    source: adapter,
                    ready: function () {
                        addfilter();
                    updatefilterpanel: function (filtertypedropdown1, filtertypedropdown2, filteroperatordropdown, filterinputfield1, filterinputfield2, filterbutton, clearbutton,
                     columnfilter, filtertype, filterconditions) {
                        if (filtertype == "datefilter") {
                            filterinputfield1.jqxDateTimeInput({ formatString: "dd-MMMM-yyyy" });
                            filterinputfield2.jqxDateTimeInput({ formatString: "dd-MMMM-yyyy" });
                    autoshowfiltericon: true,
                      { text: 'First Name', datafield: 'firstname', width: 160 },
                      { text: 'Last Name', datafield: 'lastname', width: 160 },
                      { text: 'Product', datafield: 'productname', width: 170 },
                      { text: 'Order Date', datafield: 'date', filtertype: 'date', width: 250, cellsformat: 'dd-MMMM-yyyy HH:mm' },
                      { text: 'Unit Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2' }
                $('#events').jqxPanel({ width: 300, height: 80 });
                $("#jqxgrid").on("filter", function (event) {
                    $("#events").jqxPanel('clearcontent');
                    var filterinfo = $("#jqxgrid").jqxGrid('getfilterinformation');
                    var eventData = "Triggered 'filter' event";
                    for (i = 0; i < filterinfo.length; i++) {
                        var eventData = "Filter Column: " + filterinfo[i].filtercolumntext;
                        $('#events').jqxPanel('prepend', '<div style="margin-top: 5px;">' + eventData + '</div>');
                $('#clearfilteringbutton').jqxButton({ height: 25 });
                $('#filterbackground').jqxCheckBox({ checked: true, height: 25 });
                $('#filtericons').jqxCheckBox({ checked: false, height: 25 });
                // clear the filtering.
                $('#clearfilteringbutton').click(function () {
                    $("#jqxgrid").jqxGrid('clearfilters');
                // show/hide filter background
                $('#filterbackground').on('change', function (event) {
                    $("#jqxgrid").jqxGrid({ showfiltercolumnbackground: event.args.checked });
                // show/hide filter icons
                $('#filtericons').on('change', function (event) {
                    $("#jqxgrid").jqxGrid({ autoshowfiltericon: !event.args.checked });
            <div id="jqxgrid">
            <div id="eventslog" style="margin-top: 30px;">
                <div style="width: 200px; float: left; margin-right: 10px;">
                    <input value="Remove Filter" id="clearfilteringbutton" type="button" />
                    <div style="margin-top: 10px;" id='filterbackground'>
                        Filter Background</div>
                    <div style="margin-top: 10px;" id='filtericons'>
                        Show All Filter Icons</div>
                <div style="float: left;">
                    Event Log:
                    <div style="border: none;" id="events">
    arunthatham
    thanks dimitar, it is working
    Ram
    Hi Dimitar,
    We are also facing the same problem and the above solution is worked fine but only problem we are facing is that because of the formatting inside the “updatefilterpanel” method, after filtering the data the filter value in the filter text box is not retained i.e. we could only see empty text box if we open the filter panel again after filtering.
    Is this an existing issue or any workaround to overcome this. Please help
    Many thanks
    Hi Ram,
    updatefilterpanel is called each time the filter panel is opened which means that you can set the values of the widgets which you wish.
    Ram
    Thanks for the reply. You meant to say that the above code will clear the filter text box value after filtering because of the format we are applying.
    If so then what could be done to retain the filter text box value after filtering has been applied?
    Hi Ram,
    Check whether you have or not filters using “getfilterinformation” method and if you have, don’t set properties.
    Ram
    We have tried as you suggested but still it’s not working as we expected. We have created jsfiddle demo to help you understand our expectation.
    Please have a look at this demo: http://jsfiddle.net/xjuo0ayo/
    In the above demo try to apply a filter on the “Order Date” column and after applying filter, open the “Order Date” filter panel and there will be no date in the filter text box. The same is not happening with the “Product” column.
    Kindly help to avoid this behavior as we are stuck with this issue for quite a some time now.
    Many thanks
    Hello Ram,
    Your issue seems to be related to the fact that “globalize.js” is not included. If you use jqxDateTimeInput or jqxCalendar, you should include that file. Updated Example: http://jsfiddle.net/5qmpmpwd/
    Ram
    Hello Peter,
    We have included the mentioned JS file but still we are not able to get things done. PFB for the exact steps we are following
    1. Getting the date from the server.
    2. Applying the “dd/MM/yyyy hh:mm tt” on “bindingcomplete” event
    $("#jqxgrid").bind('bindingcomplete', function () {
          $("#jqxgrid").jqxGrid('setcolumnproperty', 'date', 'cellsformat', "dd/MM/yyyy hh:mm tt");
    3. Formatting the filter input value in “updatefilterpanel”
                    filterinputfield1.jqxDateTimeInput({ formatString:"dd/MM/yyyy" });
                     filterinputfield2.jqxDateTimeInput({ formatString:"dd/MM/yyyy" });
    4. Apply the filter and open the filter panel again then the applied filtervalue will not be retained
    Please have a look at updated example : http://jsfiddle.net/5qmpmpwd/1/
    clarifications:
    1. By default jqxgrid will interpret the datetime format in “MM/dd/yyyy” when it receives from the server? If not what is the default format will JqxGrid interprets if no format is specified in the datafield?
    Could you please help.
    Many thanks
    Hello Ram,
    I suggest you to use the Approach which I suggested you and I also posted you a working sample. The sample again: http://jsfiddle.net/wo3sgcdz/ – with cellsformat set. Also the default format in the Grid is dd/MM/yyyy, not MM/dd/yyyy as you state. Let’s be correct, please.
