jQuery UI Widgets Forums Dialogs and Notifications Window Create Function for a general window?
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 11 years, 4 months ago.
  • Create Function for a general window? #48237
    realtek
    I have a site will be opening quite a few windows and I wanted to make it a bit more object orientated.
    The jqxWindow is great but if you want to have several windows displaying different content when different buttons are clicked, there is a lot of re-inventing the wheel.
    I would ideally like a common function such as createWindow() which you could pass the ID of a div to and perhaps the width and height which would then display a window.
    Does anyone have any examples of how this could be done?
    Thanks!
    Create Function for a general window? #48252
    Hello realtek,
    Here is an example of such function:
    <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
    "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
    <body>
        <div id='content'>
                    var createWindow = function (id, width, height) {
                        $("#" + id).jqxWindow({ width: width, height: height });
                    createWindow("jqxwindow", 200, 150);
            <div id='jqxwindow'>
                <div>
                    Header</div>
                <div>
                    Content</div>
