jQuery UI Widgets Forums Grid Correct way to use reference table or dictionary for display of values
This topic contains 2 replies, has 2 voices, and was last updated by  steveclay 10 years, 2 months ago.
  • steveclay
    New user alert! This is really a combination of a jqxDropDownList question and a dataAdapter question, but I’m trying to make it happen in a grid, so I’ll ask here.
    I have the following JSON data:
    [{“id”:”111″,”dayOfWeek”:”1″,”start”:”02:00″,”end”:”02:30″}]
    I want an editable grid row that looks like this:
    111 Sunday 02:00 02:30
    And I want the second column to be a drop-down with all of the days of the week in it. But I want the data for “dayOfWeek” to continue to be loaded in and sent back as an integer. Do I have to create an entire dataAdapter for the “days of the week” reference table? (I’ve done that, and can get “Sunday” to appear in the grid, but there are no other entries in the drop-down list, plus the data gets sent back to the server as “Sunday”.)
    I can try to pare my work down into a fiddle if that would be helpful; otherwise, any pointers to using reference tables/dictionaries for the display of integer data items would be appreciated. Thanks!
    -steve
    Hello steve,
    Here is how to achieve your requirement. Although the day names are displayed, the actual cell values of the “Day” column in this case will be numeric.
                var data = [{ dayOfWeek: 1, weather: 'sunny' }, { dayOfWeek: 2, weather: 'cloudy'}];
                        { name: 'dayOfWeek', type: 'int' },
                        { name: 'weather', type: 'string' }
                    localdata: data
                var days = ['Sunday', 'Monday', 'Tuesday', 'Wednesday', 'Thursday', 'Friday', 'Saturday'];
                $("#jqxgrid").jqxGrid(
                    width: 500,
                      { text: 'Day', datafield: 'dayOfWeek', width: 250, columntype: 'dropdownlist',
                          cellsrenderer: function (row, columnfield, value, defaulthtml, columnproperties) {
                              return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + ';">' + days[value - 1] + '</span>';
                              editor.jqxDropDownList({ source: ['1', '2', '3', '4', '5', '6', '7'],
                                      return days[value - 1];
                                  selectionRenderer: function (htmlString) {
                                      return days[parseInt(htmlString.text()) - 1];
                      { text: 'Weather', datafield: 'weather', width: 250 }
        <div id="jqxgrid">
    steveclay
    Dimitar: Thanks! This was perfect. Thanks for walking me through it.
    -steve
