jQuery UI Widgets Forums Lists ComboBox Combobox in Popover issue
This topic contains 1 reply, has 2 voices, and was last updated by  Martin 6 years, 9 months ago.
  • Combobox in Popover issue #101783
    Duncan
    I am trying to create a form which includes a combobox on a Popover widget, however the combobox list items are not appearing. I am not sure why this is happening, but I suspect it may be a z-index issue when the listbox portion of the combobox is created.
    var options = new Array(“Option 1”, “Option 2”, “Option 3”);
    $(“#button”).jqxButton({ theme: ‘light’, template: “inverse” });
    $(“#popover”).jqxPopover({theme: ‘light’, height: 200, offset: {left: 0, top:0}, arrowOffsetValue: 50,
    title: “Options”, position: ‘bottom’, showCloseButton: true, selector: $(“#button”) });
    $(“#header”).addClass(‘jqx-widget-header’);
    $(“#jqxComboBox”).jqxComboBox({theme: ‘light’, source: options, width: 200, height: 30});
    <div id=”popover” style=”height: 200″>
    <div id=”jqxComboBox”></div>
    Any ideas on how to solve this ?
    Combobox in Popover issue #101820
    Martin
    Hello Duncan,
    Yes, you are right. It is a z-index issue.
    You can fix it by adding the following css:
    .jqx-listbox.jqx-widget-content  {
         z-index: 9999 !important;
    Here is an Example.
    Martin
