jQuery UI Widgets Forums Lists ComboBox combobox disabled function's problem.
This topic contains 3 replies, has 3 voices, and was last updated by  cosostones 11 years, 5 months ago.
  • Sacrifice
    Hi Jqwidgets team.
    I found a combobox’s problem.
    I have 3 comboboxs. when I set disabled to all combobox. Dropdown button is disabled but It still be able to input text in combobox text.
    Just the third combobox that is disabled completely. In case set Enabled is same.
    Here is my simple code. Thank you.
    <title></title>
    <body>
    <div id='content'>
    var theme = getDemoTheme();
    var source = [
    "Affogato",
    "Americano",
    "Bicerin",
    "Breve",
    "Café Bombón",
    "Café au lait"
    // Create a jqxComboBox
    $("#jqxComboBox").jqxComboBox({ selectedIndex: 0, source: source, width: '200px', height: '25px', theme: theme });
    $("#jqxComboBox2").jqxComboBox({ selectedIndex: 1, source: source, width: '200px', height: '25px', theme: theme });
    $("#jqxComboBox3").jqxComboBox({ selectedIndex: 2, source: source, width: '200px', height: '25px', theme: theme });
    $('#Enabled').jqxCheckBox({ checked: true, width: '50px', theme: theme });
    $('#Enabled2').jqxCheckBox({ checked: true, width: '50px', theme: theme });
    $('#Enabled3').jqxCheckBox({ checked: true, width: '50px', theme: theme });
    $('#Enabled').on('change', function (event) {
    var checked = !event.args.checked;
    $("#jqxComboBox").jqxComboBox({ disabled: checked });
    $('#Enabled2').on('change', function (event) {
    $("#jqxComboBox2").jqxComboBox({ disabled: checked });
    $('#Enabled3').on('change', function (event) {
    $("#jqxComboBox3").jqxComboBox({ disabled: checked });
    <div id='jqxComboBox'></div><div id='Enabled'>Enabled ComboBox 1</div><br/>
    <div id='jqxComboBox2'></div><div id='Enabled2'>Enabled ComboBox 2</div><br/>
    <div id='jqxComboBox3'></div><div id='Enabled3'>Enabled ComboBox 3</div>
    You can use the following workaround:
    $("#jqxComboBox input").attr('disabled', true);
    $("#jqxComboBox2 input").attr('disabled', true);
    $("#jqxComboBox3 input").attr('disabled', true);
    Sacrifice
    Thank you ^_^
    combobox disabled function's problem. #45979
    cosostones
    I had the same problem ‘Sacrifice’ had.
    The workaround is working fine for now. Thanks.
    But for the future, it could be a problem if combobox structure change.
    (potential bug in our application in the future)
    So, do you know if this will be fixed in some release ?
    Regards.
    Alain.
