jQuery UI Widgets Forums Grid Column Click
This topic contains 2 replies, has 2 voices, and was last updated by  petzi 11 years, 6 months ago.
    Column Click Posts
  • Column Click #32616
    petzi
    Hi!
    I’m am trying to add a context menu to the Column header of the jqxGrid control but with no luck. I have tried to bind to the “columnclick” event but it just doesn’t work.
    We are using:
    jQuery 1.10.2
    jqWidgets 3.0.3
    IE9, Chrome (lastest), FF
    My code:
    $(“#jqxGrid”).on(“columnclick”, function (event)
    console.log(‘Working!!’);
    Regards
    Petzi
    Edit 1:
    I also tried adding this code to the demo “defaultfunctionality” without any sucess.
    Column Click #32625
    Hi Petzi,
    That code would not work for the Default Functionality demo due to the reason that the Grid’s ID used in the demo is “jqxgrid”, not “jqxGrid”.
    Working sample:
    <title id='Description'>This demo illustrates the basic functionality of the Grid plugin. The jQWidgets Grid plugin offers rich support for interacting with data, including paging, grouping and sorting.
    </title>
    var url = "../sampledata/products.xml";
    datatype: "xml",
    { name: 'ProductName', type: 'string' },
    { name: 'QuantityPerUnit', type: 'int' },
    { name: 'UnitPrice', type: 'float' },
    { name: 'UnitsInStock', type: 'float' },
    { name: 'Discontinued', type: 'bool' }
    root: "Products",
    record: "Product",
    url: url
    if (value < 20) {
    return '<span style="margin: 4px; float: ' + columnproperties.cellsalign + '; color: #ff0000;">' + value + '</span>';
    else {
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid(
    width: 670,
    altrows: true,
    enabletooltips: true,
    { text: 'Product Name', columngroup: 'ProductDetails', datafield: 'ProductName', width: 250 },
    { text: 'Quantity per Unit', columngroup: 'ProductDetails', datafield: 'QuantityPerUnit', cellsalign: 'right', align: 'right', width: 120 },
    { text: 'Unit Price', columngroup: 'ProductDetails', datafield: 'UnitPrice', align: 'right', cellsalign: 'right', cellsformat: 'c2', width: 100 },
    { text: 'Units In Stock', datafield: 'UnitsInStock', cellsalign: 'right', cellsrenderer: cellsrenderer, width: 100 },
    { text: 'Discontinued', columntype: 'checkbox', datafield: 'Discontinued' }
    columngroups: [
    { text: 'Product Details', align: 'center', name: 'ProductDetails' }
    $("#jqxgrid").on('columnclick', function (event) {
    alert('column clicked');
    <div id="jqxgrid">
    Column Click #32633
    petzi
    Hello Peter, thanks for the fast reply!
    So first problem solved, thanks!
    But is there a way to detect the rightmouse button, instead of just the left?
    I found that the event ‘rowclick’ has ‘rightclick’ but columnclick doesn’t.
