jQuery UI Widgets Forums Grid ColorPicker Problem
This topic contains 9 replies, has 2 voices, and was last updated by  simcon94 11 years, 2 months ago.
  • ColorPicker Problem #52039
    simcon94
    i have a grid with Colorpicker.
    Sometimes it works, sometimes not.
    Sometimes the first click in Colorpicker will get the color, sometimes not.
    So strange….
    My JSON:
    [{"Id":"1","Name":"Test","Color":"#000000"},{"Id":"2","Name":"Test2","Color":"#AD1703"},{"Id":"3","Name":"Test3","Color":"#2413B5"},{"Id":"4","Name":"Test4","Color":"#939B01"},{"Id":"5","Name":"Test5","Color":"#262626"},{"Id":"6","Name":"Test6","Color":"#44AF2B"},{"Id":"7","Name":"Test7","Color":"#7BFF07"},{"Id":"8","Name":"Test8","Color":"#FC1905"}]
    My Grid:
    // initialize jqxGrid
            $("#grid").jqxGrid(
                    width: sk.appHelper.getMaxContentWidth()
                    , autoheight: true
                    , source: dataAdapter
                    , editable: editable
                    , editmode: 'selectedcell'
                    , columnsresize: true
                    , columnsreorder: true
                    , groupable: true
                    , sortable: true
                    , filterable: false
                    , cellhover: function (element, pageX, pageY) {
                        var cell = $('#grid').jqxGrid('getcellatposition', pageX, pageY);
                        if (cell.column === "Delete") {
                            $("#grid").jqxTooltip({ content: '@Resources.Tooltip.DeleteButton', position: 'bottom', showDelay: 1000 });
                            // open tooltip.
                            $("#grid").jqxTooltip('open', pageX, pageY);
                    , columns: [
                            text: '', datafield: 'Delete', width: 50, columntype: 'number', hidden: hiddenDeleteButton, cellsrenderer: function () {
                                return '<div style="width: 100%"><img src="Content/icons/delete.png" style="margin-left: 25%" /></div>';
                        , { text: '@Resources.Instrument.Name', datafield: "Name", width: 190 }
                            text: '@Resources.Instrument.Color',
                            columntype: 'custom',
                            datafield: 'Color',
                            width: 220,
                            createeditor: function(row, cellvalue, editor) {
                                var dropDownButton = $("<div style='border: none;'><div style='padding: 5px;'><div class='colorPicker" + row + "'></div></div></div>");
                                dropDownButton.appendTo(editor);
                                dropDownButton.jqxDropDownButton({ width: '100%', height: '100%' });
                                var colorPicker = $($.find(".colorPicker" + row));
                                colorPicker.jqxColorPicker({ width: 220, height: 220 });
                                colorPicker.on('colorchange', function (event) {
                                   dropDownButton.jqxDropDownButton('setContent', getTextElementByColor(event.args.color));
                                dropDownButton.jqxDropDownButton('setContent', getTextElementByColor(new $.jqx.color({ hex: "ffffff" })));
                            initEditor: function(rowKey, cellvalue, editor, celltext, width, height) {
                                $($.find('.colorPicker' + rowKey)).val(cellvalue);
                            // returns the value of the custom editor.
                            getEditorValue: function(rowKey, cellvalue, editor) {
                               return $($.find('.colorPicker' + rowKey)).val();
                            cellsrenderer: function (row, columnfield, value) {
                                return getTextElementByColor(new $.jqx.color({ hex: value.substring(1) }))[0].outerHTML;
                                return '<div style="width: 100%;height: 100%; background-color:' + value + '; color: #FFFFFF"></div>';
                                //return '<div style="width: 100%;height: 100%; background-color:' + value +'; color: #FFFFFF">' + value + '</div>';
                        , { text: "Id ", datafield: "Id", width: 1, hidden: true }
    JS:
    function getTextElementByColor(color) {
            if (color == 'transparent' || color.hex == "") {
                return $("<div style='text-shadow: none; position: relative; padding-bottom: 4px; margin-top: 4px;'>transparent</div>");
            var element = $("<div style='text-shadow: none; position: relative; padding-bottom: 4px; margin-top: 4px;'>#" + color.hex + "</div>");
            var nThreshold = 105;
            var bgDelta = (color.r * 0.299) + (color.g * 0.587) + (color.b * 0.114);
            var foreColor = (255 - bgDelta < nThreshold) ? 'Black' : 'White';
            element.css('color', foreColor);
            element.css('background', "#" + color.hex);
            element.addClass('jqx-rc-all');
            return element;
    ColorPicker Problem #52042
    simcon94
    The first six rows worked…..
    ColorPicker Problem #52043
    Hi simcon94,
    You can use this solution: http://www.jqwidgets.com/community/topic/jqxcolorpicker-in-grid/. It always works.
    ColorPicker Problem #52046
    simcon94
    whats the difference?
    ColorPicker Problem #52049
    Hi simcon94,
    I suggest you to compare your code with the one from the working sample and not only the part which you posted here, because that’s not all the code. The half of the Grid’s initialization is missing and especially the Data Binding part.
    ColorPicker Problem #52050
    Hi simcon94,
    ColorPicker Problem #52052
    simcon94
    My Databinding:
                    { name: 'Id', type: 'Guid' }
                    , { name: 'Name', type: 'string' }
                    , { name: 'Color', type: 'string' }
                    commit(true);
                    commit(true);
                    $('#grid').jqxGrid('refresh');
                    commit(true);
                // get Model Data
                url: sk.appHelper.getAppDomainAppVirtualPath() + "/Instrument/GetInstruments",
    ColorPicker Problem #52055
    Hi simcon94,
    Obviously, the Casing is wrong. In the sample I posted it is: dataFields, not datafields. If you use camel-case, use it everywhere, if you use lowercase, use it everywhere. Don’t mix them. If you use lowercase, your initEditor should be initeditor, etc.
    ColorPicker Problem #52057
    simcon94
    So my whole code:
            return element;
                    commit(true);
                    commit(true);
                    commit(true);
                // get Model Data
                url: sk.appHelper.getAppDomainAppVirtualPath() + "GetData",
            var editable = true;
            var hiddenDeleteButton = false;
            $("#grid").jqxGrid(
                    , autoheight: true
                    , groupable: true
                    , sortable: true
                    , filterable: false
                            $("#grid").jqxTooltip({ content: 'DeleteButton', position: 'bottom', showDelay: 1000 });
                            // open tooltip.
                    , columns: [
                        , { text: 'Name', datafield: "Name", width: 190 }
                            text: 'Color',
                            datafield: 'Color',
                            width: 220,
                            initeditor: function(rowKey, cellvalue, editor, celltext, width, height) {
                            geteditorValue: function(rowKey, cellvalue, editor) {
    @*GRID*@
    <div id="grid"></div>
    ColorPicker Problem #52083
    simcon94
    I found the Problem……
    The Problem was:
    autoheight: true
