jQuery UI Widgets › Forums › General Discussions › Navigation › Tree › 'click' event issue while using jqxTree with drag&drop
This topic contains 5 replies, has 2 voices, and was last updated by Peter Stoev 12 years, 1 month ago.
I find an issue that on iPad Safari, while using jqxTree (allowDrag: true, allowDrop: true) in my application, the ‘click’ event for buttons is no longer valid.
I have also tried to add a button in the demo code for Drag and Drop in jqxTree and bind click event to the button, but I can never trigger the event on iPad Safari, while I can trigger it on desktop browsers.
Can you help me with above issue?
RoachHi,
I am unable to reproduce the reported behavior with the current version of jQWidgets. I modified the demo and added a button. It was clickable and the alert box was displayed as expected.
<!DOCTYPE html><html lang="en"><head> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdragdrop.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(); // Create jqxTree $('#treeA').jqxTree({ allowDrag: true, allowDrop: true, height: '300px', width: '220px', theme: theme, dragStart: function (item) { if (item.label == "Community") return false; } }); $('#treeB').jqxTree({ allowDrag: true, allowDrop: true, height: '300px', width: '220px', theme: theme, dragEnd: function (item, dropItem, args, dropPosition, tree) { if (item.label == "Forum") return false; } }); $("#treeA, #treeB").on('dragStart', function (event) { $("#dragStartLog").text("Drag Start: " + event.args.label); $("#dragEndLog").text(""); }); $("#treeA, #treeB").on('dragEnd', function (event) { $("#dragEndLog").text("Drag End"); if (event.args.label) { var ev = event.args.originalEvent; var x = ev.pageX; var y = ev.pageY; if (event.args.originalEvent && event.args.originalEvent.originalEvent && event.args.originalEvent.originalEvent.touches) { var touch = event.args.originalEvent.originalEvent.changedTouches[0]; x = touch.pageX; y = touch.pageY; } var offset = $("#textarea").offset(); var width = $("#textarea").width(); var height = $("#textarea").height(); var right = parseInt(offset.left) + width; var bottom = parseInt(offset.top) + height; if (x >= parseInt(offset.left) && x <= right) { if (y >= parseInt(offset.top) && y <= bottom) { $("#textarea").val(event.args.label); } } } }); $("#clickme").click(function () { alert('Click'); }); }); </script></head><body class='default'> <input type="button" value="click" id="clickme" /> <div id='jqxWidget'> <div style='float: left;'> <div id='treeA' style='float: left; margin-left: 0px;'> <ul> <li id='home' item-selected='true'>Home</li> <li item-expanded='true'>Solutions <ul> <li>Education</li> </ul> </li> <li>Financial services</li> <li>Community</li> </ul> </div> <div style='float: left; margin-left: 20px;' id="treeB"> <ul> <li>Products </li> <li item-expanded='true'>Support <ul> <li>Support home</li> <li>Customer Service</li> </ul> </li> <li>Knowledge base</li> <li>Forum</li> </ul> </div> <div style="width: 200px; height: 200px; float: left; margin-left: 20px;"> <textarea rows="5" id="textarea"></textarea> </div> </div> <div style="font-size: 13px; font-family: Verdana; padding-top: 20px; clear: both;"> <b>Events Log:</b> <div id="dragStartLog"> </div> <div id="dragEndLog"> </div> <br /> <b>Note:</b> <br /> Dragging of "Community" is disabled. <br /> Dropping of "Forum" is disabled. </div> </div></body></html>
Please, provide a sample which demonstrates your issue.
My code is nearly same as yours, as below,
<!DOCTYPE html><html lang="en"><head> <meta name="keywords" content="jQuery Tree, Tree Widget, TreeView" /> <meta name="description" content="The jqxTree displays a hierarchical collection of items. You can populate it from 'UL' or by using its 'source' property." /> <title id='Description'>The sample demonstrates the Tree's drag and drop functionality. </title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxdragdrop.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(); // Create jqxTree $('#treeA').jqxTree({ allowDrag: true, allowDrop: true, height: '300px', width: '220px', theme: theme, dragStart: function (item) { if (item.label == "Community") return false; } }); $('#treeB').jqxTree({ allowDrag: true, allowDrop: true, height: '300px', width: '220px', theme: theme, dragEnd: function (item, dropItem, args, dropPosition, tree) { if (item.label == "Forum") return false; } }); $("#treeA, #treeB").on('dragStart', function (event) { $("#dragStartLog").text("Drag Start: " + event.args.label); $("#dragEndLog").text(""); }); $("#treeA, #treeB").on('dragEnd', function (event) { $("#dragEndLog").text("Drag End"); if (event.args.label) { var ev = event.args.originalEvent; var x = ev.pageX; var y = ev.pageY; if (event.args.originalEvent && event.args.originalEvent.originalEvent && event.args.originalEvent.originalEvent.touches) { var touch = event.args.originalEvent.originalEvent.changedTouches[0]; x = touch.pageX; y = touch.pageY; } var offset = $("#textarea").offset(); var width = $("#textarea").width(); var height = $("#textarea").height(); var right = parseInt(offset.left) + width; var bottom = parseInt(offset.top) + height; if (x >= parseInt(offset.left) && x <= right) { if (y >= parseInt(offset.top) && y <= bottom) { $("#textarea").val(event.args.label); } } } }); $("#test_btn").click(function(){ alert("works"); }); }); </script></head><body class='default'> <div id='jqxWidget'> <div style='float: left;'> <div id='treeA' style='float: left; margin-left: 0px;'> <ul> <li id='home' item-selected='true'>Home</li> <li item-expanded='true'>Solutions <ul> <li>Education</li> </ul> </li> <li>Financial services</li> <li>Community</li> </ul> </div> <div style='float: left; margin-left: 20px;' id="treeB"> <ul> <li>Products </li> <li item-expanded='true'>Support <ul> <li>Support home</li> <li>Customer Service</li> </ul> </li> <li>Knowledge base</li> <li>Forum</li> </ul> </div> <div style="width: 200px; height: 200px; float: left; margin-left: 20px;"> <textarea rows="5" id="textarea"></textarea> </div> </div> <div style="font-size: 13px; font-family: Verdana; padding-top: 20px; clear: both;"> <b>Events Log:</b> <div id="dragStartLog"> </div> <div id="dragEndLog"> </div> <br /> <b>Note:</b> <br /> Dragging of "Community" is disabled. <br /> Dropping of "Forum" is disabled. </div> </div> <div><input type="button" value="test" id="test_btn"/></div></body></html>
I also tried your code above, but it still didn’t work on iPad (iOS version 6.1.2 and 6.1.3). But on my iPod(iOS version 4.2.1), samsung tablet and android phones, it worked well.
RoachHi Peter,
Just update and clarification below,
I’d like to talk about the click issue on iPad. I’m getting the issue where the click event for buttons is not working on my application with jqxTree and jqxGrid.
FYI, related to jqxGrid, I’ve tried on your demo site http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/dragdrop.htm?web on iPad and found the previous/next buttons do not respond. FYI, no issues on desktop browsers.
Can you try the same link above on your iPad? And let me know if you have the same issue?
This is the issue I’m trying to explain above that needs to be fixed.
Look forward to hearing back from you soon!
Roach
Just checking to see if you have had any time to try the below issue on an iPad:
FYI, related to jqxGrid, I’ve tried on your demo site http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/dragdrop.htm?web on iPad and found that drag & drop works but the previous/next buttons do not work – e.g. not responding.
Just FYI, no issues found on desktop browsers.
A quick reply would be greatly appreciated.
Roach
We found out what the issue with jqxDragDrop plug-in is and we created a work item about it. The fix will be available in the next version.
