jQuery UI Widgets Forums Lists DropDownList checkchange event problem
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 9 months ago.
  • checkchange event problem #29636
    Dundee
    i have that kind of code :
    $("#cblSitesUpload").on('checkChange', function (event) {
    var item=event.args.item;
    if (item.value == 0 && !item.checked) {
    $("#cblSitesUpload").jqxDropDownList('checkAll');
    $("#cblSitesUpload").jqxDropDownList('uncheckIndex',0);
    This dropdown list regroup a list of item..and when i unselect the “All item” checkbox..i need to checkall item except the the one i just uncheck……but when i test this code..it’s fire error like this “item is undefined”
    What i do wrong??
    I readed on this forum that checkall fire event for all event..but if it’s work for the first one i uncheck..why this error..
    checkchange event problem #29648
    Hi Dundee,
    The problem is that you do check/uncheck in a ‘checkChange’ event. ‘checkAll’ will raise ‘checkChange’ and so do ‘uncheckIndex’. Implementation with ‘checkAll’ is already available – http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/customfiltering.htm?arctic
