jQuery UI Widgets › Forums › Grid › Checkbox Column not editable
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 9 years, 10 months ago.
Hi all,
I am facing a problem regarding the checkbox column… they are not editable – even if I set editable: true.
All other columns can be edited if I want to…
Can somebody help me?Here is my code:
var datafields = [ { name: 'Name', type: 'string' }, { name: 'Email', type: 'string' }, { name: 'Type', type: 'string' }, { name: 'AccountId', type: 'string'}, { name: 'ContactId', type: 'string'} ]; var overviewSource = { datatype: "json", datafields: datafields, localData: JSON.stringify(data), }; var overviewDataAdapter = new $.jqx.dataAdapter(overviewSource, { loadComplete: function () { //var length = dataAdapter.records.length; $.each(overviewDataAdapter.records, function(i, v){ v.EmailToBeSent = false; v.EmailSent = false; v.Participated = false; }) } }); $("#div").jqxGrid({ source: overviewDataAdapter }); $("#div").jqxGrid( { width: '100%', editable: true, autoheight: true, ready: function () { //$(TrainingsAppConstants.formAttendeesGridDiv).jqxGrid('autoresizecolumn', 'Email'); //$(TrainingsAppConstants.formAttendeesGridDiv).jqxGrid('autoresizecolumn', 'EmailToBeSent'); //$(TrainingsAppConstants.formAttendeesGridDiv).jqxGrid('autoresizecolumn', 'EmailSent'); //$(TrainingsAppConstants.formAttendeesGridDiv).jqxGrid('autoresizecolumn', 'Participated'); }, columns: [ { text: 'ID', datafield: 'ID', hidden:true, editable: false }, { text: 'AccountId', datafield: 'AccountId', hidden:false, editable: false }, { text: 'ContactId', datafield: 'ContactId', hidden:false, editable: false }, { text: 'Type', datafield: 'Type', cellsrenderer: typeRenderer, width: 20, editable: false }, { text: 'Name', datafield: 'Name' }, { text: 'Email', datafield: 'Email', editable: false}, { text: 'Email to be Sent', datafield: 'EmailToBeSent', threestatecheckbox: false, columntype: 'checkbox' }, { text: 'Email Sent', datafield: 'EmailSent', threestatecheckbox: false, columntype: 'checkbox' }, { text: 'Participated', datafield: 'Participated', threestatecheckbox: false, columntype: 'checkbox' }, ], groupable: true, groups: ['AccountId'] });
Hi Claudio,
Look at the Editing demos where there is CheckBox column which is editable. Apply the same approach to get the desired results. Another problem is that your data source does not have defined datafields for the checkbox columns.
thanks for your quick response.I modified my datafields now like this:
var datafields = [ { name: 'Name', type: 'string' }, { name: 'Email', type: 'string' }, { name: 'Type', type: 'string' }, { name: 'AccountId', type: 'string'}, { name: 'ContactId', type: 'string'}, { name: 'EmailToBeSent', type: 'bool'}, { name: 'EmailSent', type: 'bool'}, { name: 'Participated', type: 'bool'} ];
Unfortunately it didn’t solve the problem.
I’m also binding<script type="text/javascript" src="../Scripts/jqwidgets/jqx-all.js"></script>
to make sure everything’s there.My problem was solved as I switched back to jQWidgets v3.8.0 (2015-Apr)…
Could it be, that there is an issue in this build?Hi Claudio,
Taking the fact that it works in the online demos, it’s not an issue with the current build.
