jQuery UI Widgets Forums Grid Check box sorting/checkstate problem
This topic contains 7 replies, has 2 voices, and was last updated by  flyingmag 12 years ago.
  • flyingmag
    Hello.
    I have a grid with an editable checkbox column. When I check some rows and sort by the check-state everything works as expected, but if I unsort on that column again and check another checkbox and sort on that column again, the new entry is unchecked again. If I check another checkbox while sorting on the column, both the newly checked row and the row that was not checked correctly gets checked and sorted again. This only occurs when doing the unsorting by clicking on the checkbox column header, not if the sorting is changed by clicking some other column header.
    I.e you have some implementation of custom Row selection scenario where you sort/unsort the Grid. Btw. if you have such scenario, the selection column should not be sortable according to me as its purpose is to select/unselect rows. Would you provide a sample which demonstrates your scenario?
    flyingmag
    If you use the demo on the page (http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxgrid/index.htm#demos/jqxgrid/checkboxcolumn.htm) and enable sorting and editing on the grid you should get the same behaviour.
    or you can use this code instead:
    Test
    @section scripts
    var theme = ‘energyblue’;
    var data = preparegriddata(10);
    localdata: data,
    datatype: “array”,
    datafields:
    { name: ‘available’, type: ‘bool’ },
    { name: ‘quantity’, type: ‘number’ }
    commit(true);
    var columnCheckBox = null;
    var updatingCheckState = false;
    // initialize jqxGrid. Disable the built-in selection.
    $(“#jqxgrid”).jqxGrid(
    enablehover: false,
    selectionmode: ‘none’,
    pageable: false,
    text: ”, menu: false, sortable: true, editable: true,
    datafield: ‘available’, columntype: ‘checkbox’, width: 40,
    renderer: function () {
    return ‘
    rendered: function (element) {
    $(element).jqxCheckBox({ theme: theme, width: 16, height: 16, animationShowDelay: 0, animationHideDelay: 0 });
    columnCheckBox = $(element);
    $(element).on(‘change’, function (event) {
    var checked = event.args.checked;
    var pageinfo = $(“#jqxgrid”).jqxGrid(‘getpaginginformation’);
    var pagenum = pageinfo.pagenum;
    var pagesize = pageinfo.pagesize;
    if (checked == null || updatingCheckState) return;
    $(“#jqxgrid”).jqxGrid(‘beginupdate’);
    // select all rows when the column’s checkbox is checked.
    if (checked) {
    $(“#jqxgrid”).jqxGrid(‘selectallrows’);
    // unselect all rows when the column’s checkbox is checked.
    else if (checked == false) {
    $(“#jqxgrid”).jqxGrid(‘clearselection’);
    // update cells values.
    var startrow = pagenum * pagesize;
    for (var i = startrow; i < startrow + pagesize; i++) {
    // The bound index represents the row's unique index.
    // Ex: If you have rows A, B and C with bound indexes 0, 1 and 2, afer sorting, the Grid will display C, B, A i.e the C's bound index will be 2, but its visible index will be 0.
    // The code below gets the bound index of the displayed row and updates the value of the row's available column.
    var boundindex = $("#jqxgrid").jqxGrid('getrowboundindex', i);
    $("#jqxgrid").jqxGrid('setcellvalue', boundindex, 'available', event.args.checked);
    $("#jqxgrid").jqxGrid('endupdate');
    return true;
    { text: 'First Name', editable: false, datafield: 'firstname', width: 90 },
    { text: 'Last Name', editable: false, datafield: 'lastname', width: 90 },
    { text: 'Product', editable: false, datafield: 'productname', width: 200 },
    { text: 'Quantity', editable: false, datafield: 'quantity' }
    var updatePageState = function (pagenum) {
    var datainfo = $("#jqxgrid").jqxGrid('getdatainformation');
    var pagenum = datainfo.paginginformation.pagenum;
    var pagesize = datainfo.paginginformation.pagesize;
    // select the rows on the page.
    $("#jqxgrid").jqxGrid('beginupdate');
    var checkedItemsCount = 0;
    var value = $("#jqxgrid").jqxGrid('getcellvalue', boundindex, 'available');
    if (value) checkedItemsCount++;
    if (value) {
    $("#jqxgrid").jqxGrid('selectrow', boundindex);
    else {
    $("#jqxgrid").jqxGrid('unselectrow', boundindex);
    if (checkedItemsCount == pagesize) {
    columnCheckBox.jqxCheckBox({ checked: true });
    else if (checkedItemsCount == 0) {
    columnCheckBox.jqxCheckBox({ checked: false });
    else {
    columnCheckBox.jqxCheckBox({ checked: null });
    // update the selection after sort.
    $("#jqxgrid").on('sort', function (event) {
    updatePageState();
    // update the selection after page change.
    $("#jqxgrid").on('pagechanged', function (event) {
    updatePageState();
    // select or unselect rows when a checkbox is checked or unchecked.
    $("#jqxgrid").on('cellvaluechanged', function (event) {
    if (event.args.value) {
    $("#jqxgrid").jqxGrid('selectrow', event.args.rowindex);
    else {
    $("#jqxgrid").jqxGrid('unselectrow', event.args.rowindex);
    // update the state of the column's checkbox. When all checkboxes on the displayed page are checked, we need to check column's checkbox. We uncheck it,
    // when there are no checked checkboxes on the page and set it to intederminate state when there is at least one checkbox checked on the page.
    if (columnCheckBox) {
    var selectedRows = $("#jqxgrid").jqxGrid('getselectedrowindexes');
    var state = false;
    var count = 0;
    $.each(selectedRows, function () {
    if (pagenum * pagesize <= this && this < pagenum * pagesize + pagesize) {
    count++;
    if (count != 0) state = null;
    if (count == pagesize) state = true;
    if (count == 0) state = false;
    updatingCheckState = true;
    $(columnCheckBox).jqxCheckBox({ checked: state });
    function preparegriddata(rowscount) {
    var data = new Array();
    var firstNames =
    var lastNames =
    var productNames =
    "Black Tea", "Green Tea", "Caffe Espresso", "Doubleshot Espresso", "Caffe Latte", "White Chocolate Mocha", "Caramel Latte", "Caffe Americano", "Cappuccino", "Espresso Truffle", "Espresso con Panna", "Peppermint Mocha Twist"
    var row = {};
    row["available"] = false;
    row["quantity"] = quantity;
    data[i] = row;
    return data;
    1. You may check also the implementation of the the Grid’s Default Functionality sample(the first sample) which has a CheckBox column, Editing is enabled and Sorting is enabled, too. Btw. if you sorted the Checkbox column, and then you check/uncheck a cell, the Sort will be updated depending on the cell’s new value – true or false.
    2. The posted code will not work because it is based on our Demo with Custom Row Selection which is a Sample of a Grid with Pager enabled and the code in the demo assumes that Paging is enabled. The provided code is with disabled Paging so the Custom row selection in that case will not work unless you modify the other parts of the custom selection logic, too.
    Check box sorting/checkstate problem #21743
    Here’s a sample based on the Checbox Column sample with Enabled Editing and Sorting. I am unable to reproduce the reported behavior with jQWidgets 2.8.3
    <title id='Description'>This example shows how to show a checkbox column in the Grid plugin.
    </title>
    var theme = getDemoTheme();
    var data = generatedata(20, true);
    localdata: data,
    datafields:
    datatype: "array"
    width: 670,
    { text: 'Available', datafield: 'available', columntype: 'checkbox', width: 70 },
    { text: 'Unit Price', datafield: 'price', cellsalign: 'right', cellsformat: 'c2' }
    <div id="jqxgrid">
    Check box sorting/checkstate problem #21749
    flyingmag
    The demo you referred to have the exact same problem as I am experiencing. Easily reproduced by checking some boxes. Click the checkbox column header twice and you see all checked rows first in the list. Click the header once more to loose the sorting. Select one or more checkboxes more. Click the header again to make a sorting, and you can see that the new rows you selected does not sort. The checked status is maintained in this example though. Tested in both firefox and IE10.
    Check box sorting/checkstate problem #21751
    Using your new explanation I now understood the issue and was able to reproduce it.
    Here’s a workaround:
                $("#jqxgrid").on('cellvaluechanged', function () {
    $("#jqxgrid").jqxGrid('dataview').clearsortdata();
    Check box sorting/checkstate problem #21753
    flyingmag
    Thanks, that seems to work perfectly.
