jQuery UI Widgets Forums Editors CheckBox, RadioButton Check-box doesn’t appear when using knockout.
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 11 months ago.
  • mullai.b
    Hi All,
    Tried Demo code of knockout checkbox. But the checkbox doesn’t appear
    <html lang=”en”>
        <title id=”Description”>Integration of jqxCheckBox with Knockout</title>
        <script type=”text/javascript” src=”../../scripts/jquery-1.8.3.min.js”></script>
        <script type=”text/javascript” src=”../../scripts/json2.js”></script>
        <script type=”text/javascript” src=”../../scripts/knockout-2.2.1.js”></script>
        <script type=”text/javascript” src=”../../scripts/gettheme.js”></script>
        <script type=”text/javascript” src=”../../jqwidgets/jqxknockout.js”></script>
                var viewModel = function (value) {
                    this.count = 0;
                    this.checked = ko.observable(value);
                    this.disabled = ko.observable(false);
                    // display checked state.
                    this.getState = function () {
                        alert(“Checked: ” + this.checked());
                    // check checkbox.
                    this.check = function () {
                        this.checked(true);
                    // toggle disabled state.
                    this.toggle = function () {
                        this.count++;
                        this.disabled(this.count % 2);
                ko.applyBindings(new viewModel(true));
    <body class=’default’>
            <div data-bind=”jqxCheckBox: {checked: checked, disabled: disabled, width: ‘120px’, theme: getDemoTheme()}” style=’margin-bottom: 10px;’>jqxCheckBox</div>
            <input data-bind=”click: getState, jqxButton: {theme: getDemoTheme()}” type=”button” value=”Get Value” />
            <input data-bind=”click: check, jqxButton: {theme: getDemoTheme()}” type=”button” value=”Set Value” />
            <input data-bind=”click: toggle, jqxButton: {theme: getDemoTheme()}” type=”button” value=”Toggle Disabled” />
    Mullai malar
    Hi Mullai malar
    We have a working Online sample which the CheckBox – http://jqwidgets.com/jquery-widgets-demo/demos/jqxknockout/checkbox.htm,
    In case that does not work for your, then please check whether the references to the scripts are correct.
