jQuery UI Widgets Forums Chart Charts min/max values
This topic contains 1 reply, has 2 voices, and was last updated by  Vladimir 9 years, 7 months ago.
  • Charts min/max values #76688
    ziggy
    I’ve downloaded the version 3.9.0 and I noticed that the min/max values has been changed from integer to decimal (w/ 2 decimal places).
    How can we set it back as integer using the latest version?
    Also, export to jpeg/png doesn’t work still on my end. However, export to pdf works. Please help.
    Thanks.
    Karen
    Charts min/max values #76703
    Vladimir
    Hello Karen,
    Regarding your fist question you can use the formatFunction to achieve that:
    formatFunction: function (value) {
       return value;
    Regarding your second question here is a working example with a scatter chart export to jpeg/png.
    Vladimir
