jQuery UI Widgets › Forums › Chart › Chart throws an error when using the color function
This topic contains 8 replies, has 2 voices, and was last updated by Peter Stoev 10 years, 2 months ago.
i’ve got a problem with the jqwidgets version 3.7.0. I’m using a flipped bar chart with ranged columns to show a project schedule. I want to use the colorFunction of the series to apply different colors to the bars. This is the rendered code on the page:
<div id="chartContainer" style="width:100%; height: 480px;"></div> var data = [ { Task: 1fst Task", TaskName: "Task: 1fst Task", From: getMilliseconds(2015, 1, 1), To: getMilliseconds(2015, 1, 31), Task_State: 'Status: 0 %', Task_Done: 'False' }, { Task: "Testproject", TaskName: "Testproject", From: getMilliseconds(2015, 1, 1), To: getMilliseconds(2015, 5, 31), Task_State: '0 from 1 Tasks done', Task_Done: 'false' }]; function getMilliseconds(year, month, day) { return new Date(year, month-1, day).getTime(); } function getDDMMYY(ticks) { var date = new Date(ticks); var yy = date.getFullYear(); var mm = date.getMonth() +1; var dd = date.getDate(); if (mm < 10) mm = "0" + mm; if (dd < 10) dd = "0" + dd; return dd + "." + mm + "." + yy; } function getDayTicks(days) { return days * 86400000; } var toolTipCustomFormatFn = function (value, itemIndex, serie, group, categoryValue, categoryAxis) { return '<DIV style="text-align:left"><b>' + data[itemIndex].TaskName + '</b><br />Start: ' + getDDMMYY(value.from) + '<br />Ende: ' + getDDMMYY(value.to) + '<br />' + data[itemIndex].Task_State; }; function renderChart() { var settings = { title: "Testproject", description: "Overview", enableAnimations: false, showLegend: false, showBorderLine: true, source: data, colorScheme: 'scheme07', xAxis: { dataField: 'Task', textRotationAngle: 90, unitInterval: 1, gridLines: { visible: false } }, seriesGroups: [{ orientation: 'horizontal', type: 'rangecolumn', toolTipFormatFunction: toolTipCustomFormatFn, valueAxis: { flip: true, minValue: getMilliseconds(2015, 1, 1), maxValue: getMilliseconds(2015, 5, 31), unitInterval: getDayTicks(3), formatFunction: function (value) { if ((value / getDayTicks(2)) % 2 == 0) { return getDDMMYY(value); } return ""; }, textRotationAngle: -75 }, series: [{ dataFieldFrom: 'From', dataFieldTo: 'To', useGradientColors: false, colorFunction: function (dataValue, itemIndex, serie, group) { //Implement Color condition return '#00FF00'; } }], bands: [{ minValue: getMilliseconds(2015, 3, 10), maxValue: getMilliseconds(2015, 3, 11), color: '#FF0000', opacity: .5, lineWidth: 1 }] }] }; $('#chartContainer').children().remove(); $('#chartContainer').jqxChart(settings); }
If I include the
colorFunction
just like in the example above I get a javascript exception thrown, that says that the field
From
is undefined. This is the part of the minified script that causes the error:
_getDataValue:function(b,e,d) { var c=this.source; if(d!=undefined&&d!=-1) { c=this.seriesGroups[d].source||c } if(c instanceof a.jqx.dataAdapter) { c=c.records } if(!c||b<0||b>c.length-1) { return undefined } if(a.isFunction(e)) { return e(b,c) } return(e&&e!="")?c[b][e]:c[b] }
The variable
c
contains my data,
b
is undefined and
e
is ‘From’.
How can I call the colorFuntion without this error?Hi j.hartmann,
The provided code is not sufficient for testing your scenario. Please, prepare and share jsfiddle.net sample if you wish someone from our team to look at it.
http://www.jqwidgets.comHi j.hartmann,
Send us a support request to support@jqwidgets.com and we’ll provide you an updated file.
http://www.jqwidgets.comI have sent you a mail.
Thanks for your help.
Did you receive my e-mail? Currently I’m waiting for your response and the project is due tomorrow.
Regards
Hi j.hartmann,
We received your email and will prepare you a minified file for tomorrow morning.
http://www.jqwidgets.comThank for your help.
Hi j.hartmann,
We just sent you an email with the updated file.
