jQuery UI Widgets › Forums › Chart › Chart problem with 3.3.0
This topic contains 4 replies, has 3 voices, and was last updated by yoda 10 years, 11 months ago.
AuthorChart problem with 3.3.0 Posts
I have just uploaded to jqxWidgets 3.3.0, bu my charts are not being displayed right any more. I simply adds more categories on categoryAxis.
For example, in the code below it will display years 2006, 2007, 2008, 2009, but in the data source, as you can see there are only 2005 and 2010.
Please help!<script type="text/javascript"> $(document).ready(function () { //prepare chart data var sampleData = [ {year:2005,Industry:130.00,Transport:110.00,Residential:120.00,Commercial:230.00,Agriculture:0,Fishing:0,Non_energy_use:"",Other:""}, {year:2010,Industry:130.00,Transport:110.00,Residential:120.00,Commercial:230.00,Agriculture:0,Fishing:0,Non_energy_use:"",Other:""} ]; var settings_chart = { title: 'final energy demand bysectors', description: '', enableAnimations: true, showLegend: true, padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 90, top: 0, right: 0, bottom: 10 }, source: sampleData, categoryAxis: { dataField: 'year', showTickMarks: true, tickMarksInterval: 2, tickMarksColor: '#888888', unitInterval: 0, showGridLines: true, gridLinesInterval: 2, gridLinesColor: '#ff0000', axisSize: 'auto' }, colorScheme: 'scheme01', seriesGroups: [ { type: 'stackedcolumn', columnsGapPercent: 100, seriesGapPercent: 5, valueAxis: { unitInterval: 0, minValue: 0, maxValue: 'auto', displayValueAxis: true, description: 'PJ', axisSize: 'auto', tickMarksColor: '#888888', formatSettings: {decimalPlaces: 0} }, series: [ { dataField: 'Industry', displayText: Industry}, { dataField: 'Transport', displayText: Transport}, { dataField: 'Residential', displayText: Residential}, { dataField: 'Commercial', displayText: Commercial}, { dataField: 'Agriculture', displayText: Agriculture}, { dataField: 'Fishing', displayText: Fishing}, { dataField: 'Non_energy_use', displayText: Non_energy_use}, { dataField: 'Other', displayText: Other} ] } ] }; $('#jqxChart').jqxChart(settings_chart); }); </script> </head> <body style="background:white;"> <div id='jqxChart' style="width:600px; height: 400px"/> </body> </html>
Hi atomic,
The solution is – you should add: type: ‘basic’ to the categoryAxis
http://www.jqwidgets.com/It works!!!
Thanks Peter!Hi,
Sorry to bother you again with same issue, but the chart is little bit different now. It losses nice color rounding in tooltips, and it gets black borders in stacked columns. Here is code, try it with latest jqxwidgets and jqxwidgets3.0.4 I think and you will see difference.
Thanks<script type="text/javascript"> $(document).ready(function () { //prepare chart data var sampleData = [ {"year":"1990","Electricity":"25.00","Coal":"22.00","Oil":"15.00","Gas":"17.00","Biofuels":"5.00","Heat":"5.00","Peat":"3.00","Waste":"3.00","Oil_shale":"5.00"}, {"year":"2000","Electricity":"22.00","Coal":"18.00","Oil":"13.00","Gas":"18.00","Biofuels":"6.00","Heat":"4.00","Peat":"4.00","Waste":"10.00","Oil_shale":"5.00"}, {"year":"2010","Electricity":"28.00","Coal":"20.00","Oil":"12.00","Gas":"22.00","Biofuels":"7.00","Heat":"5.00","Peat":"0.00","Waste":"6.00","Oil_shale":"0.00"}, {"year":"2020","Electricity":"27.00","Coal":"15.00","Oil":"10.00","Gas":"25.00","Biofuels":"10.00","Heat":"8.00","Peat":"0.00","Waste":"5.00","Oil_shale":"0.00"}, {"year":"2030","Electricity":"27.00","Coal":"10.00","Oil":"5.00","Gas":"23.00","Biofuels":"15.00","Heat":"10.00","Peat":"0.00","Waste":"10.00","Oil_shale":"0.00"}, {"year":"2040","Electricity":"27.00","Coal":"10.00","Oil":"5.00","Gas":"23.00","Biofuels":"15.00","Heat":"10.00","Peat":"0.00","Waste":"10.00","Oil_shale":"0.00"}, {"year":"2050","Electricity":"27.00","Coal":"10.00","Oil":"5.00","Gas":"23.00","Biofuels":"15.00","Heat":"10.00","Peat":"0.00","Waste":"10.00","Oil_shale":"0.00"} ]; var settings_chart = { title: 'Final energy demand by sectors', //description: final_energy_demand_fuel_shares + ' ' + sector, description: '', enableAnimations: true, showLegend: true, theme: theme, padding: { left: 5, top: 5, right: 5, bottom: 5 }, titlePadding: { left: 90, top: 0, right: 0, bottom: 10 }, source: sampleData, categoryAxis: { text: 'Category Axis', type: 'basic', textRotationAngle: 0, dataField: 'year', showTickMarks: true, tickMarksInterval: 1, tickMarksColor: '#888888', unitInterval: 1, showGridLines: false, gridLinesInterval: 1, gridLinesColor: '#888888', axisSize: 'auto' }, colorScheme: 'scheme01', seriesGroups: [ { type: 'stackedcolumn', columnsGapPercent: 100, seriesGapPercent: 5, valueAxis: { unitInterval: 20, minValue: 0, maxValue: 'auto', displayValueAxis: true, description: '%', axisSize: 'auto', tickMarksColor: '#888888' }, series: [ { dataField: 'Electricity', displayText: electricity, color: clElectricity}, { dataField: 'Coal', displayText: coal, color: clCoal}, { dataField: 'Oil', displayText: oil, color: clOil}, { dataField: 'Gas', displayText: gas, color: clGas}, { dataField: 'Biofuels', displayText: biofuels, color: clBiofuels}, { dataField: 'Heat', displayText: heat, color: clHeat}, { dataField: 'Peat', displayText: peat, color: clPeat}, { dataField: 'Waste', displayText: waste, color: clWaste}, { dataField: 'Oil_shale', displayText: oil_shale, color: clOil_shale}, ] // series: series_fuels } ] }; //kraj settinga za chart // setup the chart $('#jqxChart').jqxChart(settings_chart); }); </script> </head> <body style="background:white;"> <div id='jqxChart' style="width:600px; height: 400px"/> </body> </html>
Hi atomic,
You seem to be upgrading from a much older version of the chart. According to the APIs the color property was deprecated and I guess it was kept for backwards compatibility:
http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxchart/jquery-chart-api.htmYou should be able to replace with a combination of these (copy-pasted from the documentation):
color – (Deprecated) fill color for the serie.
lineColor – Line color for the serie.
lineColorSelected – Line color for the serie when selected.
fillColor – Fill color for the serie.
fillColorSelected – Fill color for the serie when selected.
lineColorSymbol – Line color for the marker symbols in serie.
lineColorSymbolSelected – Line color for the marker symbols in the serie when selected.
fillColorSymbol – Fill color for the marker symbols in the serie.
fillColorSymbolSelected – Fill color for the the marker symbols in serie when selected.Also I find it useful to work with the custom color functions like here:
