jQuery UI Widgets › Forums › Grid › Changing Cell Border or Background color when editing and finished editing
Tagged: #jqwidgets-grid, cell grid, change color of editing cell, grid, javascript grid, jquery grid
This topic contains 2 replies, has 2 voices, and was last updated by Hristo 7 years, 11 months ago.
July 13, 2017 at 3:25 pm Changing Cell Border or Background color when editing and finished editing #94908
Hi this is my Grid and I am just trying to change border color of firstname column cells when they are being edited using this code below, but it’s not working. Please can anyone have solution for this.
<style type=”text/css”>
.current_editing
border-width: 3px !important;
border-color: #ffd000 !important;
</style>
//Documents Grid
var data = <?php echo $user_grid_data ?>;
if (data == ‘logout’)
window.location = ‘/users/logout’;
return false;
localdata: data,
{name: ‘user_id’, type: ‘int’},
{name: ‘is_active’, type: ‘bool’},
{name: ‘force_password_change’, type: ‘string’},
{name: ‘firstname’, type: ‘string’},
{name: ‘lastname’, type: ‘string’},
{name: ‘username’, type: ‘string’},
{name: ‘phone_number’, type: ‘string’},
{name: ‘position’, type: ‘string’},
datatype: “json”
var dataAdapter = new $.jqx.dataAdapter(source);var cellStyle = ”;
$(“#users_grid”).jqxGrid(
width: 900,
height: 470,
pagesize: 20,
altrows: true,
autoheight: false,
rowsheight: 20,
selectionmode: ‘singlecell’,
editmode: ‘selectedcell’,
theme: ‘glacier’,
{hidden: true, datafield: ‘user_id’, width: 0},
{text: ‘Active’, datafield: ‘is_active’, threestatecheckbox: false, columntype: ‘checkbox’, width: 50},
text: ‘Force Password Change’, datafield: ‘force_password_change’, width: 150, columntype: ‘combobox’,
createeditor: function (row, column, editor) {
var list = [‘N’, ‘Y’];
editor.jqxComboBox({autoDropDownHeight: true, source: list, promptText: “Please Choose:”});
// update the editor’s value before saving it.
cellvaluechanging: function (row, column, columntype, oldvalue, newvalue) {
// return the old value, if the new value is empty.
if (newvalue == “”)
return oldvalue;
{text: ‘First Name’, datafield: ‘firstname’, align: ‘center’, width: 150, columntype: ‘text’, cellclassname: cellStyle,
cellbeginedit: function (row, datafield, columntype) {
cellclassname= “current_editing”;
return cellclassname;
{text: ‘Last Name’, datafield: ‘lastname’, align: ‘center’, width: 150, columntype: ‘text’, cellclassname: cellStyle},
{text: ‘Email’, datafield: ‘username’, align: ‘center’, width: 200, columntype: ‘text’, cellclassname: cellStyle},
{text: ‘Phone’, datafield: ‘phone_number’, align: ‘center’, width: 100, columntype: ‘text’, cellclassname: cellStyle},
{text: ‘Position’, datafield: ‘position’, align: ‘center’, columntype: ‘text’, width: 100, cellclassname: cellStyle},
});$(“#users_grid”).on(‘rowselect’, function (event) {
var args = event.args;
var rowData = args.row;
//textboxeditorusers_gridphone_number
$(“#users_grid”).on(‘cellendedit’, function (event)
var args = event.args;var dataField = event.args.datafield;
var rowBoundIndex = event.args.rowindex;
var value = args.value;if (args.columntype == “checkbox” && dataField == “is_active”)
if (value == true)
value = ‘Y’;
} else
value = ‘N’;
var oldvalue = args.oldvalue;
var user_id = rowData[‘user_id’];send_data_to_update(dataField, value, oldvalue, user_id, “/Users/save_user”, “users”);
});July 13, 2017 at 3:43 pm Changing Cell Border or Background color when editing and finished editing #94910Or is there a way to refer a cell (like cell_id or something unique) so that I can do something like in “cellbeginedit”
$(cell_id).css(“background-color”,”#333″);July 19, 2017 at 1:52 pm Changing Cell Border or Background color when editing and finished editing #95001Hello keyur,
Unfortunately, we do not have such example.
I would like to suggest you look at our “Theme Builder” section.
There you could choose the desired ‘theme’ and after that, you could change the color of the edited cell.
You should navigate to “Inputs and dropdowns” and for you case need to change the color under “Input background” label.Best Regards,
Hristo HristovjQWidgets team
