jQuery UI Widgets Forums Grid change search engine position
This topic contains 5 replies, has 3 voices, and was last updated by  pepe 1 year, 1 month ago.
  • change search engine position #134564
    pepe
    Good evening, I am trying to put the combobox with the fields and the input with the search button on the right, but in the following order from right to left.
    1.- the search button
    2.- the imput
    3.- the combox with the fields.
    thank you
    change search engine position #134578
    admin
    Hi pepe,
    Could you explain which exactly, because the Grid has several different modes for seach and filter?
    Looking forward to your reply.
    Peter
    https://www.jqwidgets.com/
    change search engine position #134583
    pepe
    Good afternoon Peter, I attach the example code.
    All the best.
    <html lang=”en”>
    <title id=’Description’>In this sample is demonstrated how to filter through all records in the Grid.</title>
    <meta name=”description” content=”JavaScript Grid which has multiple built-in aggregates” />
    <meta http-equiv=”X-UA-Compatible” content=”IE=edge,chrome=1″ />
    <meta name=”viewport” content=”width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1″ />
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.edit.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.filter.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.sort.js”></script>
    <script type=”text/javascript” src=”../../jqwidgets/jqxgrid.aggregates.js”></script>
    <script type=”text/javascript” src=”generatedata.js”></script>
    window.onload = function() {
    var data = generatedata( 200 );
    localdata: data,
    datatype: “array”,
    datafields:
    { name: ‘available’, type: ‘bool’ },
    { name: ‘price’, type: ‘number’ }
    updaterow: function ( rowid, rowdata ) {
    var dataAdapter = new jqx.dataAdapter( source );
    // initialize jqxGrid
    var grid = new jqxGrid( “#grid”,
    width: ‘100%’,
    showfilterbar: true,
    { text: ‘First Name’, columntype: ‘textbox’, datafield: ‘firstname’, width: 170 },
    { text: ‘Last Name’, datafield: ‘lastname’, columntype: ‘textbox’, width: 170 },
    text: ‘Product’, datafield: ‘productname’, width: 170,
    text: ‘In Stock’, datafield: ‘available’, columntype: ‘checkbox’, width: 125,
    text: ‘Quantity’, datafield: ‘quantity’, width: 85, cellsalign: ‘right’, cellsformat: ‘n2’,
    text: ‘Price’, datafield: ‘price’, cellsalign: ‘right’, cellsformat: ‘c2’
    var grid2 = new jqxGrid( “#grid2″,
    width: ‘100%’,
    filterbarmode: ‘simple’,
    <script async src=”https://www.googletagmanager.com/gtag/js?id=G-2FX5PV9DNT”></script><script>window.dataLayer = window.dataLayer || [];function gtag(){dataLayer.push(arguments);}gtag(‘js’, new Date());gtag(‘config’, ‘G-2FX5PV9DNT’);</script></head>
    <body class=’default’>
    <h3>Grid with Search Input and Filter By List</h3>
    <div id=”grid”></div>
    <br />
    <h3>Grid with Search Input</h3>
    <div id=”grid2″></div>
    change search engine position #134592
    ivanpeevski
    Hi pepe,
    If I understood correctly, you want the elements in the same order, but moved to the right side of the toolbar?
    If this is the case, you can use the CSS below:
    .jqx-grid-toolbar{
    display: flex;
    justify-content: end;
    Ivan Peevski
    change search engine position #134598
    pepe
    Good afternoon Ivan, the example does exactly what I wanted.
    Thank you so much
    change search engine position #134689
    pepe
    Good evening, how could I add a button to the left of the search engine.
    Thank you
