jQuery UI Widgets › Forums › Chart › Category Axis — Help
This topic contains 0 replies, has 1 voice, and was last updated by sushanth009 13 years ago.
AuthorCategory Axis — Help Posts
Hello Peter,
I am working the column graphs currently. I noticed that when the CategoryAxis dataField starts with a number, it is not being rendered on the chart. But if it starts with a alphabet it seems to be working fine.. Is this a know issue or am I making a mistake in here. I am attaching the code with this code..
The code used to populate the Graph is
var source = {
datafields: [{
localdata: result,
datatype: 'json'
var settings = {
title: "Service Locations",
showLegend: true,
enableAnimations: false,
padding: {
left: 15,
top: 5,
right: 15,
bottom: 5
titlePadding: {
left: 90,
top: 0,
right: 0,
bottom: 10
categoryAxis: {
dataField: 'a',
showGridLines: true,
text: 'Service Locations',
textRotationAngle: -90,
colorScheme: 'scheme01',
seriesGroups: [{
type: 'column',
valueAxis: {
unitInterval: 1000,
displayValueAxis: true,
description: 'Cost'
series: [{
dataField: 'c',
displayText: 'Cost'
};$('#csl-charts-main').jqxChart(settings);
The json Object for the First case where it seems to working is
{ "a":"Unreg_Lights", "c":"10705.97"}, { "a":"Pool", "c":"9344.96" },{ "a":"OFC_102Leasing", "c":"8676.12"},
{ "a":"Parking_Deck", "c":"7654.00" }, { "a":"Club_101", "c":"6776.79" }, { "a":"Bldg_6", "c":"6427.92" },
{ "a":"Bldg_4", "c":"6136.03" }, { "a":"Panel_1", "c":"6008.17"}, { "a":"Exercise_2","c":"5941.89" },
{ "a":"Panel_3", "c":"4053.98"}, { "a":"Bldg_7", "c":"3951.26" }, { "a":"Shop_226", "c":"3661.31" },
{ "a":"Bldg_5", "c":"3067.62" }, { "a":"REC_105Exercise", "c":"2886.03"}, { "a":"Panel_2", "c":"2765.45"},
{ "a":"Elevator", "c":"793.36" }
]The graph rendered is http://img827.imageshack.us/img827/5168/chartnoerror.png
The json Object for which it does not seem to work is
{ “a”:”10_Perimeter_Park”,”c”:”24348.74″},
{ “a”:”10_Perimeter_Park_Drive”,”c”:”8128.22″},
{ “a”:”12_Perimeter_Park_Dr”,”c”:”6131.09″ },
{ “a”:”10_Perimeter_Park_Dr”, “c”:”607.48″ }
]The image that is rendered is http://img688.imageshack.us/img688/435/charterror.png
Can you look into this and let me know where i am going wrong..
