jQuery UI Widgets Forums Editors Calendar Calendar display problem
This topic contains 1 reply, has 2 voices, and was last updated by  Dimitar 12 years, 5 months ago.
  • Calendar display problem #12592
    zorba
    I have a calendar in a toolbar that has multiple widgets stacked up for 3 rows below it. When I click the calendar it seems to want to popup below these rows, but the header is obscurred and the first row of days is partly obscurred. I want make the popup stick to the textbox it is bound to. How do I achieve this?
    Thanks!
    Lee…
    Calendar display problem #12637
    Hello Lee,
    I assume you are actually talking about the jqxDateTimeInput widget and its calendar pop-up. We tried to reproduce the reported behaviour but to no avail. Please make sure you use the latest version of jQWidgets (as of now it is 2.5.5). If the issue persist, please post a code snippet which we may test locally.
