jQuery UI Widgets Forums Plugins Validator, Drag & Drop, Sortable c.offset(…) is undefined on validate
This topic contains 3 replies, has 2 voices, and was last updated by  darkelf 10 years, 6 months ago.
  • c.offset(…) is undefined on validate #62560
    darkelf
    Hi;
    I using to validator for check user input. But sometimes take to this error.
    TypeError: c.offset(…) is undefined
    …var i=a(q.input);c=a(q.input);j.push(c);h=c.offset().top;if(e>h){e=h;g=c}}d–;if… jqxvalidator.js (line 7, col 1119)
    It’s often work. But sometimes (I dont know how) give error like this…
    (I not sure to paste my code. Because its evaluate from your example code…)
    thanks
    c.offset(…) is undefined on validate #62572
    Nadezhda
    Hello darkelf,
    Please, provide a sample which illustrates your issue.
    Nadezhda
    c.offset(…) is undefined on validate #62604
    darkelf
    Ok. I have progress in my code.
    I have two dropdown field. I need at least one field selected. I mean user must select field one, field two or field one + field two.
    My code is:
    { input: ‘#field1’, message: ‘Mandotory Field!’, action: ‘keyup, blur’, rule:
    function () {
    if ($(‘#field1’).val() > 0 || $(‘#field2’).val() > 0) { return true; } else { return false; }
    { input: ‘#field2’, message: ‘Mandotory Field!’, action: ‘keyup, blur’, rule:
    function () {
    I have’nt got any error after loading. But while using i got
    error.
    I trying to comment one block like this:
    function () {
    function () {
    it’s work vell.
    Any idea of this stuation?
    thanks.
    c.offset(…) is undefined on validate #62607
    darkelf
    Ok my mistake. L solve my problem.
    L made a typo. I type field1 -> filed1
    Thanks.
