jQuery UI Widgets Forums Grid Button click setcellvalue for Selected rows
This topic contains 4 replies, has 2 voices, and was last updated by  dan123 7 years, 7 months ago.
  • dan123
    Hi i have this grid with two price columns, Price 1 and Price 2. Once i have some rows selected, I am trying to setcellvalue to match both the columns whenever i edit in ‘Price 2 column’ and click the submit button to perform the update. Only Price 2 column is editable.
    I created a logic but it seems to update only one row. If there is workaround, it will be very helpful.
    Example:
    Columns Price 1 Price 2
    Row 1 $4.00 $4.00 Checkbox checked
    Row 2 $3.70 $3.70 Checkbox checked
    Row 3 $4.20 $4.20 Checkbox checked
    Next
    Edited all Rows
    Row 1 $4.00 $1.00 Checkbox checked
    Row 2 $3.70 $2.70 Checkbox checked
    Row 3 $4.20 $2.20 Checkbox checked
    Final
    Next click ‘Submit’ button to match the same values from Price 2 column to Price 1 column based on if checkbox were selected.
    Row 1 $1.00 $1.00 Checkbox checked
    Row 2 $2.70 $2.70 Checkbox checked
    Row 3 $2.20 $2.20 Checkbox checked
    Here is my jsfiddle:
    https://jsfiddle.net/UbK74/1385/
    dan123
    Ok. Sorry I fixed the above issue.
    But now i am trying to figure out something based on the calculations.
    I have another grid 2, that basically will be populated by the “Submit” button which will send down my edited value from Price 2 column to grid2 through addrow method. I already created this logic. Also in this grid2 there is a “Delete” button column, to revert back changes to the main grid.
    I need help with reverting back the “Price 1 and Price 2” values based on the rows i delete from grid2.
    For example:
    Grid 1: i Edited the values of Row 1 twice, originally it was $4.00
    Row 1 $2.00 $2.00 Checkbox not checked
    Grid 2:
    Columns Price 2 Delete
    Row 1 $1.00 Delete button
    Row 2 $1.00 Delete button
    Output
    If i delete Row 1 from Grid 2, it should revert the changes to Grid 1’s both Price 1 and 2 Columns
    Grid 2
    Deleted Row 1
    Grid 1
    Row 1 $3.00 $3.00 Checkbox not checked
    Now if i deleted the last row too from Grid 2.
    Final output of Grid 1 will be
    Grid 1
    Row 1 $4.00 $4.00 Checkbox not checked
    https://jsfiddle.net/xfd7b4ad/11/
    Button click setcellvalue for Selected rows #97511
    Stanislav
    Hello dan123,
    I would suggest you, to just make an array and store in it all the values that you send to the second grid(the original values of the selected rows from the first grid). That way if you want to revert a change from the second grid, you have the original value.
    I am sorry if you didn’t get the answer you hoped for. If you have any more questions, please, feel free to ask them here, and I will try to as detailed as possible.
    Stanislav
    dan123
    Ok i did what you said kind of using “getrows” method to check for rows with specific firstname. In the example i know its in array and randomly generating firstnames, but this is just for example. So i figured out the problem, but now i am having a different problem where whenever i delete a row from grid 2 its not applying the changes correctly to grid 1 and i cannot seem to delete all rows from grid 2.
    Problem: its reverting the changes based on the latest row, deleting all rows from grid 2 not working, and lastly if select all rows from grid 1 to edit and set them to grid 2 as I delete them they are all going to index 1 of grid 1.
    So for example: Look at rows that only have different name cause this being randomized so.
    Grid 1:
    Row 1: $1.00
    Grid 2
    Row 1: $1.00 iF I DELETE THIS ROW, for some reason its applying ‘Row 2’ value to Grid 1 Price columns
    Row 2: $2.00
    Observed:
    Grid 1:
    Row 1: $3.00
    if i delete the last row of Grid 2, its using that same value and outputting as
    Grid 1:
    Row 1: $5.00
    here is my jsfiddle:
    https://jsfiddle.net/xfd7b4ad/34/
    Button click setcellvalue for Selected rows #97520
    dan123
    Hey use this jsfiddle: I updated it
    https://jsfiddle.net/xfd7b4ad/40/
