jQuery UI Widgets › Forums › TreeGrid › Button Click Event Not Fire in TreeGrid cell
This topic contains 3 replies, has 2 voices, and was last updated by Peter Stoev 10 years ago.
I have created a treegrid and 4 cusom buttons. Edit, Delete, AddChild, AddSibling. If am click any of the above 4 button row click event only fire instead of particular button events. Please find the code below and give me the solution.
<!DOCTYPE html> <html ng-app="jqxgridAngular"> <head> <title></title> <script src="js/jquery.js"></script> <script src="angular.min.js"></script> <link href="jqwidgets/styles/jqx.base.css" rel="stylesheet" type="text/css" /> <script src="jqwidgets/jqx-all.js"></script> <script type="text/javascript"> var app = angular.module('jqxgridAngular', ["jqwidgets"]); app.controller('StoryboardController', function ($scope) { $scope.sceneGrid = [ { "scid": 49, "scname": "Scene 1", "sctag": "SCN_1", "scrank": 1, "scstatus": "D", "scwork": 60, "sclevel": 1 }, { "scid": 50, "scname": "Scene 1.1", "sctag": "SCN_11", "scrank": 1, "scstatus": "D", "scwork": 30, "sclevel": 2 }, { "scid": 51, "scname": "Scene 2", "sctag": "SCN_2", "scrank": 2, "scstatus": "D", "scwork": 4, "sclevel": 1 }, { "scid": 52, "scname": "Scene 3", "sctag": "SCN_3", "scrank": 3, "scstatus": "D", "scwork": 15, "sclevel": 1 }, { "scid": 53, "scname": "Scene 4", "sctag": "SCN_4", "scrank": 4, "scstatus": "D", "scwork": 30, "sclevel": 1 }, { "scid": 54, "scname": "Scene 4.1", "sctag": "SCN_41", "scrank": 1, "scstatus": "D", "scwork": 15.5, "sclevel": 2 }, { "scid": 55, "scname": "Scene 4.1.1", "sctag": "SCN_411", "scrank": 1, "scstatus": "D", "scwork": 8, "sclevel": 3 }, { "scid": 56, "scname": "Scene 4.1.2", "sctag": "SCN_411", "scrank": 2, "scstatus": "D", "scwork": 8, "sclevel": 3 }, { "scid": 57, "scname": "Scene 5", "sctag": "SCN_411", "scrank": 5, "scstatus": "D", "scwork": 2, "sclevel": 1 } ]; //columns which is from stored procedure will be binds to tree grid $scope.source = { dataType: "json", dataFields: [ //Columns in the database that will bind to treegrid { name: 'scid', type: 'number' }, { name: 'scname', type: 'string' }, { name: 'sctag', type: 'string' }, { name: 'scrank', type: 'int' }, { name: 'scstatus', type: 'string' }, { name: 'scwork', type: 'number' }, { name: 'sctarget', type: 'date' }, { name: 'sclevel', type: 'number' } ], hierarchy: { keyDataField: { name: 'scid' }, parentDataField: { name: 'scid' } }, id: 'scid', localData: $scope.sceneGrid }; //setting folder icon to root node $scope.dataAdapter = new $.jqx.dataAdapter($scope.source, { beforeLoadComplete: function (records) { for (var i = 0; i < records.length; i++) { var imgUrl = "./images/folder.png"; records[i].icon = imgUrl; } return records; } }); $scope.dataAdapter.dataBind(); // create Tree Grid $scope.sceneGridSettings = { height: 250, icons: true, width: "100%", editable: true, source: $scope.dataAdapter, sortable: true, filterable: true, filterMode: 'advanced', columns: [ { text: 'scid', dataField: 'scid', editable: false, width: 110, hidden: true }, { text: 'Scene Name', dataField: 'scname', editable: false, width: 110 }, { text: 'sctag', dataField: 'sctag', editable: false, width: 110, hidden: true }, { text: 'Rank', datafield: 'scrank', width: 50, editable: true, align: 'right', cellsalign: 'right' }, { text: 'Status', dataField: 'scstatus', editable: false, width: 110 }, { text: 'Work', dataField: 'scwork', editable: false, width: 70 }, { text: 'Target', dataField: 'sctarget', editable: false, width: 110 }, { text: 'Level', dataField: 'sclevel', editable: false, width: 110, hidden: true }, { text: '', dataField: 'stid', sortable: false, editable: false, filterable: false, cellsrenderer: function (row, columnDataField, value) { return ' <button id="ed' + row + '" ng-click="editScene(' + row + ');">Edit</button>' + ' <button id="de' + row + '" ng-click="deleteScene(' + row + ');">Delete</button>' + ' <button id="ac' + row + '" ng-click="AddChild(' + row + ');">Add Child</button>' + ' <button id="as' + row + '" ng-click="AddSibling(' + row + ');">Add Sibling</button>'; }, width: 300 } ] }; //display name in tooltip var rendererName = function (row, columnfield, value, defaulthtml, columnproperties) { return '<div class="col-xs-5" title="' + value + '" style="padding: 0"><span>' + value + '</span></div>' } // invoked when a row clicked $('#jqxSceneTreeGrid').on('rowClick', function (event) { console.log('Row Click Event Calling'); }); // invoked when a add child button clicked $scope.AddChild = function () { console.log('Add Child Function Calling'); } // invoked when a add child button clicked $scope.AddSibling = function () { console.log('Add Sibling Function Calling'); } //invoked when a delete icon is clicked $scope.deleteScene = function (sceneID) { console.log('Delete Event Fire : ' + sceneID); } //invoked when the edit icon is clicked $scope.editScene = function (sceneID) { console.log('Edit Event Fire : ' + sceneID); } }); </script> </head> <body ng-controller="StoryboardController"> <jqx-tree-grid jqx-settings="sceneGridSettings" id="jqxSceneTreeGrid" jqx-instance="jqxSceneTreeGrid"> </jqx-tree-grid> </body> </html>
hi iplan,
See: http://www.jqwidgets.com/jquery-widgets-demo/demos/jqxtreegrid/javascript-tree-grid-command-column.htm?arctic. This is how Clicks should be handled. cellsRenderer is expected to return plain HTML to replace the default rendering of the widget. You cannot attach events there.
http://www.jqwidgets.comHi Peter Stoev,
Thanks for your reply. In the above condition i edit the column rank. after complete my edit i want call some function. how to fire it. I need in Angular.js. I tried in cellendedit event but not fire. please find the code below.
<!DOCTYPE html> <html ng-app="jqxgridAngular"> <head> <title></title> <script src="js/jquery.js"></script> <script src="angular.min.js"></script> <link href="jqwidgets/styles/jqx.base.css" rel="stylesheet" type="text/css" /> <script src="jqwidgets/jqx-all.js"></script> <script type="text/javascript"> var app = angular.module('jqxgridAngular', ["jqwidgets"]); app.controller('StoryboardController', function ($scope) { var data = [ { "scid": 49, "scname": "Scene 1", "sctag": "SCN_1", "scrank": 1, "scstatus": "D", "scwork": 60, "sclevel": 1, "plugin1": true, "plugin2": false }, { "scid": 50, "scname": "Scene 1.1", "sctag": "SCN_11", "scrank": 1, "scstatus": "D", "scwork": 30, "sclevel": 2, "plugin1": false, "plugin2": true }, { "scid": 51, "scname": "Scene 2", "sctag": "SCN_2", "scrank": 2, "scstatus": "D", "scwork": 4, "sclevel": 1, "plugin1": true, "plugin2": true }, { "scid": 52, "scname": "Scene 3", "sctag": "SCN_3", "scrank": 3, "scstatus": "D", "scwork": 15, "sclevel": 1, "plugin1": false, "plugin2": false }, { "scid": 53, "scname": "Scene 4", "sctag": "SCN_4", "scrank": 4, "scstatus": "D", "scwork": 30, "sclevel": 1, "plugin1": false, "plugin2": true }, { "scid": 54, "scname": "Scene 4.1", "sctag": "SCN_41", "scrank": 1, "scstatus": "D", "scwork": 15.5, "sclevel": 2, "plugin1": true, "plugin2": true }, { "scid": 55, "scname": "Scene 4.1.1", "sctag": "SCN_411", "scrank": 1, "scstatus": "D", "scwork": 8, "sclevel": 3, "plugin1": true, "plugin2": false }, { "scid": 56, "scname": "Scene 4.1.2", "sctag": "SCN_411", "scrank": 2, "scstatus": "D", "scwork": 8, "sclevel": 3, "plugin1": false, "plugin2": false }, { "scid": 57, "scname": "Scene 5", "sctag": "SCN_411", "scrank": 5, "scstatus": "D", "scwork": 2, "sclevel": 1, "plugin1": true, "plugin2": false } ]; $scope.sceneGrid = data; $scope.source = { dataType: "json", dataFields: [ //Columns in the database that will bind to treegrid { name: 'scid', type: 'number' }, { name: 'scname', type: 'string' }, { name: 'sctag', type: 'string' }, { name: 'scrank', type: 'int' }, { name: 'scstatus', type: 'string' }, { name: 'scwork', type: 'number' }, { name: 'sctarget', type: 'date' }, { name: 'sclevel', type: 'number' } ], hierarchy: { keyDataField: { name: 'scid' }, parentDataField: { name: 'scid' } }, id: 'scname', localData: $scope.sceneGrid }; //setting folder icon to root node $scope.dataAdapter = new $.jqx.dataAdapter($scope.source, { beforeLoadComplete: function (records) { for (var i = 0; i < records.length; i++) { var imgUrl = ""; records[i].icon = imgUrl; } return records; } }); $scope.dataAdapter.dataBind(); // create Tree Grid $scope.sceneGridSettings = { height: 250, icons: true, width: "100%", editable: true, source: $scope.dataAdapter, sortable: true, filterable: true, filterMode: 'advanced', columns: [ { text: 'scid', dataField: 'scid', editable: false, width: 110, hidden: true }, { text: 'Scene Name', dataField: 'scname', editable: false, width: 110 }, { text: 'sctag', dataField: 'sctag', editable: false, width: 110, hidden: true }, { text: 'Rank', datafield: 'scrank', width: 50, editable: true, align: 'right', cellsalign: 'right' }, { text: 'Status', dataField: 'scstatus', editable: false, width: 110 }, { text: 'Work', dataField: 'scwork', editable: false, width: 70 }, { text: 'Target', dataField: 'sctarget', editable: false, width: 110 }, { text: 'Level', dataField: 'sclevel', editable: false, width: 110, hidden: true }, { text: '', dataField: 'stid', sortable: false, editable: false, filterable: false, cellsrenderer: function (row, columnDataField, value) { return ' <button id="ed' + row + '" ng-click="editScene(' + row + ');">Edit</button>' + ' <button id="de' + row + '" ng-click="deleteScene(' + row + ');">Delete</button>' + ' <button id="ac' + row + '" ng-click="AddChild(' + row + ');">Add Child</button>' + ' <button id="as' + row + '" ng-click="AddSibling(' + row + ');">Add Sibling</button>'; }, width: 300 } ] }; $("#jqxSceneTreeGrid").on('cellendedit', function (event) { alert('1'); var args = event.args; $("#cellendeditevent").text("Event Type: cellendedit, Column: " + args.datafield + ", Row: " + (1 + args.rowindex) + ", Value: " + args.value); }); var valuchange = function (row, columnfield, value, defaulthtml, columnproperties) { console.log(value); } //display name in tooltip var rendererName = function (row, columnfield, value, defaulthtml, columnproperties) { return '<div class="col-xs-5" title="' + value + '" style="padding: 0"><span>' + value + '</span></div>' } // invoked when a row clicked $('#jqxSceneTreeGrid').on('rowClick', function (event) { console.log('Row Click Event Calling'); }); // invoked when a add child button clicked $scope.AddChild = function () { console.log('Add Child Function Calling'); } // invoked when a add child button clicked $scope.AddSibling = function () { console.log('Add Sibling Function Calling'); } //invoked when a delete icon is clicked $scope.deleteScene = function (sceneID) { console.log('Delete Event Fire : ' + sceneID); } //invoked when the edit icon is clicked $scope.editScene = function (sceneID) { console.log('Edit Event Fire : ' + sceneID); } }); </script> </head> <body ng-controller="StoryboardController"> <jqx-tree-grid jqx-settings="sceneGridSettings" id="jqxSceneTreeGrid" jqx-instance="jqxSceneTreeGrid"> </jqx-tree-grid> </body> </html>
Hi iplan,
cellEndEdit is not supposed to be raised when a Button is clicked. This event is raised when an Editor which is in Edit mode exits the Edit mode. From your code, it seems that you did not even take a look at the sample I posted you.
