jQuery UI Widgets Forums Navigation Menu, Context Menu box shadow and jqxMenu
This topic contains 2 replies, has 2 voices, and was last updated by  bronson3 13 years, 1 month ago.
  • box shadow and jqxMenu #3955
    bronson3
    I\’d like to surround each sub menu with a CSS3 box shadow. The problem is shadow width and the blur distance aren\’t taken in calculation for the parent div\’s width.
    Is there an break through ?
    Thks for answering
    box shadow and jqxMenu #3959
    Minko
    Blocked
    here is a solution for your problem:
    CSS:
    <style type="text/css">
    .dropdown-shadow
    -webkit-box-shadow: 5px 4px 10px #333333;
    .dropdown-parent
    padding-left: 7px;
    padding-top: 7px;
    padding-right: 7px;
    </style>
    JavaScript:
    //Initialization of jqxMenu
    $("#jqxMenu").jqxMenu({ width: '600', height: '30px', theme: 'classic' });
    //Set shadow to jqxMenu's submenus and padding to their wrapper
    $('.jqx-menu-dropdown').addClass('dropdown-shadow').parent().addClass('dropdown-parent');
    In the code above after the initialization of jqxMenu you have to set shadow to all it’s submenus and padding to the submenu’s wrapper.
    If your shadow is with bigger length the padding should be bigger.
    Minko
    http://jqwidgets.com/
    box shadow and jqxMenu #3971
    bronson3
    It works fine.
    Many thks.
    For display purposes i’ve added a margin left attribute on dropdown-parent css
    .dropdown-parent
    padding-left: 7px;
    padding-top: 7px;
    padding-right: 7px;
    margin-left : 15px; // open direction is left
