jQuery UI Widgets Forums Grid Data binding to grid using jquery ajax post is not working
This topic contains 3 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 10 months ago.
  • sampath
    Can any one help me.
    In my application , I’m using the Jqxgrid , binding the data to grid using pagemethod concept it was working fine, but now I want to use the jquery ajax concept to get the data from server and update to dropdown control . I’m able to get the data but not able to bind it in grid.
    Here is my sample code
    type: “POST”,
    url: “JQueryData.aspx/GetFrequencyData”,
    dataType: “json”,
    success: function (result) {
    OnGetFrequencyComplete(result);
    function OnGetFrequencyComplete(result) {
    var FrequencySource =
    { name: ‘FrequencyName’ },
    { name: ‘FrequencyId’ }
    localdata: result,
    J Sampath Kumar.
    In your code, the OnGetFrequencyComplete function is defined after the Ajax call. According to me OnGetFrequencyComplete is possible to be undefined at the point where you call it. I suggest you to debug that code and check that.
    sampath
    Hello Peter,
    I have debugged it , I’m getting the same output result from server and binding same data to control but still not able to see the data in dropdown control.
    J Sampath Kumar,
    Osmosys.
    You can get the same output from the server, but if your Grid initialization function – OnGetFrequencyComplete is undefined when you try to call it, that does not much matter, because the Grid will not be initialized.
