jQuery UI Widgets Forums General Discussions Lists DropDownList Best way to add a Label to a dropdown?
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 6 months ago.
  • Best way to add a Label to a dropdown? #48360
    realtek
    I have a dropdownlist but because the way jqwidgets uses div’s. What is the best way to add a label next to the dropdownlist?
    For example, I have tried this:
    <h1 class=”itemtitle”>Themes</h1>
    <span>Global Theme:</span><div style=”display:inline-block” ID=”divThemeSelection”></div>
    But it doesn’t display correctly… I don’t think you can use <label> wrapped around a div.
    What is the recommended approach for this? (i’m sure its simple!)
    Thanks!
    Best way to add a Label to a dropdown? #48366
    Hi realtek,
    There are multiple ways. May be the easiest is to use “float: left;”.
