jQuery UI Widgets Forums Grid Avoid Total for a Node
This topic contains 3 replies, has 2 voices, and was last updated by  Todor 6 years ago.
  • Avoid Total for a Node #105093
    parthrawal
    Hi
    I have a grid which has 3 Nodes. CAPEX/OPEX and REVEX. Currently it is showing total for all 3 nodes but i want to show total for only CAPEX and OPEX. How do i achieve this functionality in grid. ?
    Grid Total
    Avoid Total for a Node #105102
    Todor
    Hello parthrawal,
    You want to hide the cells under Total column for REVEX? Is that the wanted behavior? Or you want the behavior as in this example, but only for the CAPEX/OPEX?
    Todor
    https://www.jqwidgets.com
    Avoid Total for a Node #105116
    parthrawal
    Lets Say CAPEX has $25, OPEX has $100 and REVEX has $100 then at the bottom where we show Grand total. I would like to show only (CAPEX + OPEX) =$125 instead of grand total of $225
    Avoid Total for a Node #105123
    Todor
    Hello parthrawal,
    There is no built-in functionality for this. I’ve created an example with a workaround. Please review it whether it fits your needs.
    Todor
