jQuery UI Widgets Forums Grid autoloadstate issue with jqWidgets 3.0
This topic contains 6 replies, has 4 voices, and was last updated by  juanbill 11 years, 2 months ago.
  • autoloadstate issue with jqWidgets 3.0 #27123
    gediminas
    Hello!
    I just updated to jqWidgets 3.0.0. There seems to be an issue with autoloadstate set to true. In a grid with server-side filtering, sorting and paging enabled I get a “Uncaught RangeError: Maximum call stack size exceeded” exception when the grid is trying to autoload the state.
    autoloadstate issue with jqWidgets 3.0 #27124
    Hi gediminas,
    I do not think that “autoloadstate” should be used when you do Server Paging, Sorting and Filtering as the state in this case will be loaded on each data refresh which in that case will happen very frequently.
    autoloadstate issue with jqWidgets 3.0 #27125
    gediminas
    So if I need the state to be autoloaded only when the page was loaded, which callback should I use?
    autoloadstate issue with jqWidgets 3.0 #27126
    You can use the loadstate method and call it in the Grid’s ready callback.
    cirrus
    Hi guys,
    When I set autoloadstate and autosavestate to true then it also keeps the height of the table. I don’t want the height state to be saved and I have to use a autoheight=false.
    Cheers,
    Cirrus
    juanbill
    Great product.
    I am also following this question.
    Is it possible to exclude the height variable when autosavestate and autoloadstate is set to true.
    My init code is below.
    Sometimes the user can resize the window, and I would like the height to be re-adjusted to
    height: $(window).height()-40,
    not retain the saved height. (I have a toolbar with a height of 40 pixels so the idea of using percentage is avoided).
    Thanks heaps,
    juan
    init code ….
    $(“#jqxgrid”).jqxGrid(
    width: ‘100%’,
    autoheight: false,
    autoloadstate: false,
    autosavestate: false,
    columnsreorder: true,
    showfilterrow: true,
    altrows: true,
    groupsexpandedbydefault: true,
    groupable: true,
    showgroupsheader: false,
    selectionmode: ‘multiplerowsextended’,
    groupsrenderer: groupsrenderer,
    theme: ‘metro’,
    juanbill
    i managed to get to work with the following.
    I tried inserting
    $(‘#jqxgrid’).jqxGrid({ height: $(window).height()-40 });
    in
    $(“#jqxgrid”).bind(‘bindingcomplete’, function(){
    as well as
    //located near bottom of page
    $(window).on(“load”, function(){
