jQuery UI Widgets Forums Grid autoheight and height work together?
This topic contains 1 reply, has 2 voices, and was last updated by  ivailo 8 years, 5 months ago.
  • autoheight and height work together? #89914
    walker1234
    1) Does the above two features work together? I want to have autoheight feature with the pageable: true option. But in the scenario, when there is no data available, the autoheight feature shrinks the grid to very small size. I was wondering if it’s possible to set the height in this case of non availability of any data. I tried using both but it looks like defining fixed height doesn’t work.
    2) By default, the pageable : true sets the grid to 10 rows, is it possible to have it reduced to 5 rows?
    autoheight and height work together? #89953
    ivailo
    Hi walker1234,
    Both features are not created to work together, but you can create a workaround for it.
    You can set autoheight:true by default and calculate in the ready callback how many rows you have. If their count is below particular number to set
    autoheight:false,
    height:180
    for example.
    If you want 5 rows – set pagesize: 5.
    Please, refer to the following grid example.
    Ivailo Ivanov
