jQuery UI Widgets › Forums › Grid › Autocomplete Element behind grid title
This topic contains 6 replies, has 2 voices, and was last updated by GabrieleMartino 12 years, 4 months ago.
I have the element of an autocomplete that appear behind the title of a grid.
I think i must set different z-index in the css, does any know the property to change because is impossible with firebug to see at the autocomplete name.Thanks
Hello GabrieleMartino,
Please, provide us with a code snippet so that we may test it and be of help.
http://www.jqwidgets.com/I think is better to see the page source code…
for the element of the autocomplete
The grid element is build inside a div of name grid2 with
jQuery(“#grid2”).jqxGrid(
width: ‘95%’,
theme: “office”,
/*ready: function () {
addfilter();
//autoshowfiltericon: true,
selectionmode: ‘multiplecellsextended’,
{ text: ‘IP’, datafield: ‘ip’, width: ‘15%’ },
{ text: ‘Description’, datafield: ‘description’, width: ‘15%’ },
{ text: ‘Username’, datafield: ‘username’, width: ‘10%’ },
{ text: ‘Name’, datafield: ‘complete_name’, width: ‘15%’, cellsalign: ‘right’ },
{ text: ‘Action’, datafield: ‘group_description’, width: ‘15%’, cellsalign: ‘right’ },
{ text: ‘Operation’, datafield: ‘category’, width: ‘15%’, cellsalign: ‘right’ },
{ text: ‘Date’, datafield: ‘creation_time’, width: ‘15%’, cellsalign: ‘right’, cellsformat: ‘yyyy-M-dd H:mm:ss’ }
});The input element is written with an array of values arr in the following
jQuery(“#input1”).jqxInput({placeHolder: “Enter an IP”, height: 25, width: 200, minLength: 1, theme: “office”, source: arr});
Firebug give me the z-index of the element of the div with default
for the element of the header of the column and in firebug
element.style {
height: 100%;
left: 0;
position: absolute;
width: 162.15px;
z-index: 499;
}Further i found in the css
.jqx-grid-column-header a:link, .jqx-grid-column-header a:visited
*color: expression(this.parentNode.currentStyle[‘color’]);
}with the *. Is it an error?
Hi GabrieleMartino,
Set the position property of the input to static either through the page style or via jQuery, i.e.:
$("#input1").css("position", "static");
This should solve the issue.
http://www.jqwidgets.com/Hello,
it didn’t work. I also notice that if i click with mouse on input it appear me some element of the autocomplete in grey, and that therefore seems to have 2 autocomplete in one.
Hi GabrieleMartino,
Please share your entire page source code, so that we may test for the reported behaviour locally.
http://www.jqwidgets.com/I modified the css,
overriding the z-index property to 9999
of the .jqx-menu-dropdownlist .
