jQuery UI Widgets › Forums › General Discussions › Lists › ComboBox › autocomplete and backspace issue
This topic contains 5 replies, has 3 voices, and was last updated by Peter Stoev 10 years, 4 months ago.
can you please confirm whether this is a known bug and if there is potentially a fix/workaround ?
1. For a combobox with multiselect and autocomplete enabled, select one item.
2. Start typing “a”, then hit backspace (to delete the “a” only)
3. The a and the selected item get deleted instead of just the “a”. This is also the case when having any number of other items selected.If I disable “autocomplete” everything works fine, so it seems to be specific to that property.
Example code:
JS:
var source = [ "mona", "steph", "deb", "nancy", "joe", "rot", "andy", "mike", "sandy"]; // Create a jqxComboBox $("#jqxComboBox").jqxComboBox({ source: source, width: '200px', height: '25px', autoComplete : true, multiSelect : true, dropDownHeight : 135, dropDownWidth : 200, showArrow : true });
HTML:
<div id='jqxComboBox'></div>
SteveHello Steve,
You can use the following example:
<!DOCTYPE html> <html lang="en"> <head> <title></title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/jquery-1.11.1.min.js"></script> <script type="text/javascript" src="../../scripts/demos.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxlistbox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcombobox.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcheckbox.js"></script> </head> <body> <div id='content'> <script type="text/javascript"> $(document).ready(function () { var source = new Array("mona", "steph", "deb", "nancy", "joe", "rot", "andy", "mike", "sandy"); // Create a jqxComboBox $("#jqxComboBox").jqxComboBox({ source: source, multiSelect: true, width: 200, height: 25 }); // trigger selection changes. $("#jqxComboBox").on('change', function (event) { var items = $("#jqxComboBox").jqxComboBox('getSelectedItems'); var selectedItems = "Selected Items: "; $.each(items, function (index) { selectedItems += this.label; if (items.length - 1 != index) { selectedItems += ", "; } }); $("#log").text(selectedItems); }); }); </script> <div style="margin-top: 5px;" id='jqxComboBox'> </div> <div style="margin-top: 10px; font-size: 13px; font-family: Verdana;" id="log"></div> </div> </body> </html>
NadezhdajQWidgets team
http://www.jqwidgets.com/Thanks Nadezhda,
while your example works, it does not have the autoCpmplete property set to true as in my example.
If you enable it you will see the issue I have described in your code as well. So it’s really the combination of both autoComplete and multiSelect that is causing the issue. Can you please try to replicate it and see if it can be fixed ?cheers,
SrteveHi Steve,
Thank you for your feedback. We will investigate why it occurs.
http://www.jqwidgets.com/Nadezhda,
could you please give me an update on when this would be potentially fixed? I have sent you a separate support email with my companies license information (on 11-Mar) which should hopefully help prioritizing this.
cheers,
SteveHey Steve,
We will investigate whether there is or isn’t an issue with backspace. In case we reproduce it, we will create a work item. This means that when we release a new version and you find that item within the Release Notes, it is resolved.
