jQuery UI Widgets Forums Lists DropDownList Auto saving fiels values
This topic contains 1 reply, has 2 voices, and was last updated by  Peter Stoev 11 years, 2 months ago.
  • Auto saving fiels values #50952
    mallepaddi
    Hi
    I do have a form having many Dropdown / Input fields.
    Question is — I need to auto save entries of all fields when user selection changes from one product to another.
    I need to make ajax calls only when i found field value changed and do i need to make ajax call on ‘blur’ of each and every field ?
    Auto saving fiels values #50956
    Hi mallepaddi,
    DropDownList raises an event called “change” when its value is changed. You can add your logic in the “change” event handler.
