Hi.
I have another Kanban problem when repopulating with a filtered version of data.
_populateKanban is called, storing the actual length of source, then define a function to apply to all source items (using closure for the variable storing the length of source) then _populateKanban is called again (from _serializeSource) with less items, calling again h.resources.bindBindingUpdate that calls the function declared in _populateKanban, but the closure still have the length of the previous source, not the actual source => index out of range exception when setting kanban-item-id.
Not so simple to explain with the mignified version.
Just try to repopulate with the same items minus the first one for example.
Thanks.
Ludovic.
