jQuery UI Widgets Forums Getting Started Angular5 JqxGrid columnReorder not working for dynamically show/hide columns
This topic contains 1 reply, has 2 voices, and was last updated by  Hristo 7 years, 6 months ago.
  • govi-p
    I Created jqxWidgets grid as follows,
    <jqxGrid #colorGrid (onRowselect)=”spotColorGridOnRowSelect($event)” (onRowclick)=”spotColorGridOnRowClick($event)” (onBindingcomplete)=”spotColorGridOnBindComplete($event)”
    [width]=”‘100%'” [height]=”‘100%'” [source]=”dataAdapter” [columns]=”columns” [autoheight]=”false” [pageable]=”false” [sortable]=”true”
    [columnsresize]=”true” [columnsreorder]=”true” [editmode]=”‘programmatic'” [theme]=”‘efi'” [altrows]=”false” [enabletooltips]=”false” [editable]=”false” [scrollbarsize]=”12″
    [selectionmode]=”‘multiplerowsextended'” [selectedrowindex]=”‘4′” [showsortmenuitems]=”false” [handlekeyboardnavigation]=”handlekeyboardnavigation”
    [showgroupmenuitems]=”false”>
    </jqxGrid>
    In typescript I written logic for, Add/Remove(show/Hide) column of the Grid. When I am loading my webpage that time whatever column is present that I can able to Reorder. But After showing a column dynamically by clicking the add button, That column i cant drag.
    ANy solution for this?
    Hello govi-p,
    I tested an example with your settings based on the “Show/Hide Columns” demo and it seems to work fine.
    It looks like the reason of this issue is contained in one of your additional implementations – spotColorGridOnRowSelect, spotColorGridOnRowClick, spotColorGridOnBindComplete and handlekeyboardnavigation.
    You could try to check them. If exclude one by one and check the result.
    I would like to ask you is there any error message?
