jQuery UI Widgets Forums Angular Angular JQXChart jqxPlot scale is not a function
This topic contains 3 replies, has 2 voices, and was last updated by  svetoslav_borislavov 1 year, 7 months ago.
  • m.rossi
    Hi, when i try to test my built project that use jqxChart served on the company stage environment, i have this kind of error
    https://prnt.sc/ChAaMXI3A_fH
    https://prnt.sc/tW8iw_0KLOL8
    This error does not appears in my local environment while i’m developing.
    Any idea how to solve it?
    Hi, which version of jQWidgets are you using?
    Can you also share the settings of your Chart
    Svetoslav Borislavov
    https://www.jqwidgets.com/
    m.rossi
    I’m actually using the 16.0.1 version of JQWidgets.
    There’s a snippet of the settings, but anyway, on local environment(the developing env), with the same settings, the graph works.
        //x axis settings
        this.xAxis = {
          dataField: 'x',
          type: this.graphic.xType || 'default',
          valuesOnTicks: true,
          minValue: this.graphic.xMinValue,
          maxValue: this.graphic.xMaxValue,
          padding: {left: 0, top: 15, right: 0, bottom: 15},
          tickMarks: {
            visible: true,
            // interval: this.xInterval,
            color: '#E0E0E0'
          // unitInterval: this.xInterval,
          gridLines: {
            visible: true,
            color: '#E0E0E0'
          title: {
            text: this.graphic.xLabel,
            class: 'value-axis-label',
            offset: {x: 0, y: 15}
          labels: {
            formatFunction: (value) => {
              if (this.graphic.xType === 'date') {
                const dateValue = new Date(value);
                return <code>${('0' + dateValue.getDate()).slice(-2)}/${toTitleCase(dateValue.toLocaleString('default', {month: 'long'}))}/${dateValue.getFullYear()}</code>;
              } else {
                return this.graphic.xDecimals ? value.toFixed(this.graphic.xDecimals) : value;
            angle: 0,
            rotationPoint: 'topright',
            offset: {x: -5, y: 5}
          } as ChartXAxis
        // value axis settings
        this.valueAxis = {
          visible: true,
          title: {
            text: this.graphic.yLabel,
            offset: {x: -15, y: 0}
          minValue: this.graphic.yMinValue,
          maxValue: this.graphic.yMaxValue,
          unitInterval: this.graphic.yUnitInterval,
          padding: {left: 15, top: 0, right: 15, bottom: 0},
          tickMarks: {visible: true, color: '#BCBCBC'},
          formatSettings: {
            decimalPlaces: this.graphic.yDecimals || -1
        } as ChartValueAxis;
        this.seriesGroups = [
            type: this.graphic.seriesGroupType,
            toolTipFormatFunction: this.toolTipCustomFormatFn.bind(this),
            series: this.graphic.seriesGroupLabels.map((label, labelIndex) => {
              if (this.graphic.seriesGroupColors && this.graphic.seriesGroupColors[label]) {
                this.seriesColors[label] = this.graphic.seriesGroupColors[label];
              } else {
                this.seriesColors[label] = labelIndex <= chartColors.length ? chartColors[labelIndex] : this.selectColor(Math.floor(Math.random() * 10), 10);
              return {
                dataField: <code>y${labelIndex}</code>,
                displayText: label,
                colorFunction: (_: any) => {
                  return this.seriesColors[label];
              } as ChartSerie
    May you try removing the offset properties from the title object for the xAxis and value Axis
