jQuery UI Widgets Forums Grid AJAX POST vs. Grid POST
This topic contains 4 replies, has 3 voices, and was last updated by  Luis 4 years, 8 months ago.
  • AJAX POST vs. Grid POST #56099
    mcfloyd
    I am trying to have my grid get the headers and data from the same route based on a couple of keys I send through. For some reason, the grid is sending the data in a different (GET I think) format than the Ajax. Here’s some of the source:
    MY AJAX:
    type: “POST”,
    url: url,
    data: JSON.stringify(myData),
    dataType: “json”,
    complete: function(response){
    What is sent to the server (inspected in browser – request payload):
    data: “xxx”
    expansion: “xxx”
    grid: “xxx”
    module: “xxx”
    GRID AJAX:
    var mySource =
    type: “POST”,
    url: url,
    data: myData,
    contenttype: “application/json; charset=utf-8”,
    datafields: myDatafields,
    root: “rows”,
    filterscount=0&groupscount=0&pagenum=0&pagesize=10&recordstartindex=0&recordendindex=10&module=xxx&expansion=xxx&grid=xxx&data=xxx
    If I JSON.stringify this, it ends up being garbage.
    Is there any way I can use the grid AJAX to send my POST properly?
    AJAX POST vs. Grid POST #56126
    Hi mcfloyd,
    If type: “POST” is set, the Grid will use POST instead of GET. If you want to format the data sent to the server, you may implement the jqxDataAdapter’s formatData callback function.
    AJAX POST vs. Grid POST #56155
    mcfloyd
    I can’t seem to change the format of the data going to the server. When I console.log inside the formatData method, it looks like what I should be sending to the server an object with all of its properties, but then it still sends it as param1=1&param2=2&param3=3&etc…
    Any ideas how to do this?
    AJAX POST vs. Grid POST #56157
    mcfloyd
    Ah nevermind I got it!
    I did a
    var settings = {
    formatData: function(data){
    data = JSON.stringify(data);
    return data;
    var myDataAdapter = new $.jqx.dataAdapter(mySource, settings);
    AJAX POST vs. Grid POST #113264
    Luis
    Thank you mcfloyd, I was struggling a couple of days with this. Your solution worked perfectly. This one is a bit shorter:
        formatData: function (data) {
            return JSON.stringify(data);
