jQuery UI Widgets Forums General Discussions Ajax calls with credentials
This topic contains 5 replies, has 2 voices, and was last updated by  Peter Stoev 11 years, 9 months ago.
  • Ajax calls with credentials #32258
    petzi
    Is there a possibility to pass the credentials through the dataadapter?
    Using xhrFields { withCredentials : true } does not work with the dataadapter.
    Overriding the loadServerData funcion leads to problems with date-fields. they are not recognized as date anymore but are treated like strings.
    Thanks in advance
    Ajax calls with credentials #32259
    Hi petzi,
    At present there is no such option in jqxDataAdapter and loadServerData will not recognize the dataFields because by using loadServerData you override the built-in logic with a custom one.
    Ajax calls with credentials #32263
    petzi
    but how does the builtin logic recognize/parse the json-reply?
    Is there a possibility to call the builtin logic?
    I cannot find anything in your min-file.
    Regards
    Petzi
    Ajax calls with credentials #32266
    Hi Petzi,
    You can learn more about the built-in logic here: http://www.jqwidgets.com/jquery-widgets-documentation/documentation/jqxdataadapter/jquery-data-adapter.htm
    Ajax calls with credentials #32275
    petzi
    Hi!
    I’ve read this article. Thats how I learned about the loadServerData-Function.
    But I don’t want to handle everything by myself.
    I tried to manipulate the jqXHR-Object in the beforeSend-function but this didn’t work.
    By the way: When I use loadServerData beforeSend is never called.
    Is there another way to pass the xhrFields to the ajax call?
    Regards
    Petzi
    Ajax calls with credentials #32280
    Hi Petzi,
    loadServerData completely override the jqxDataAdapter’s built-in logic which means that its callback functions will be most probably not called. In a previous post, I wrote you that the feature you are looking for is still not supported by jqxDataAdapter so you can go with an ordinary Ajax call and in case you want to load a widget through jqxDataAdapter, in your Ajax function’s success callback, fill the jqxDataAdapter.
