jQuery UI Widgets › Forums › Lists › ListBox › Add Data to Listbox from DB with ID and VALUES
This topic contains 5 replies, has 3 voices, and was last updated by Peter Stoev 9 years ago.
I need to add data to multiple listbox with checkbox. I am using ‘addItem’ property to achieve this. But I am able to add only text. My requirement is to display text in listbox with ID Values. Onclick of the checkbox i need to pass ID’s to DB. PLease provide some info.
Please refer below sample code:$.ajax({
type: “POST”,
url: urlLOB,
data: { lobID: item },
success: function (returndata) {if (args.checked) {
debugger;
var LobCount;
for (LobCount = 0; LobCount < returndata.data.length; LobCount++) {$("#LstFamParent").jqxListBox('addItem', returndata.data[LobCount].PlatformFamilyBrandName );
Note: "returndata.data[LobCount].PlatformFamilyBrandName" is my List item text.
"returndata.data[LobCount].PlatformFamilyID" is my List item ID.
Please provide some info ASAP
Hi mohan raj,
To add items from external source like JSON, XML, etc. I suggest you to take a look at this sample: listboxbindingtojson.htm.
Note that the ‘addItem’ method adds a new item. You can add an item like that: {label: “My Item”, value: “My ID”}.
To send the values of your items to the server, you need to dynamically create a data object and set the ajax’s “data” field to point to your object.
Example:
var params = { id:"Item" }; var str = jQuery.param(params);
The result is: id=Item
In your server script, you should check whether there’s the “id” is set.
if (isset($_POST['id'])){ $itemID = $_POST['id']; }
Hope this helps.
http://www.jqwidgets.comHi , i am trying to bind json data to my list box but getting error. Below is my code :
var channelGrpTypeKey = $(‘#ddlChannelGroupType’).val();
var url = “/MappingChannelGroup/GetChannelsByGrpTypeKeyAndGrpNameKey”;var source =
{ name: ‘ChannelName’ },
{ name: ‘ChannelKey’ }
ChannelGrpTypeKey: channelGrpTypeKey,
srcFuncAreaKey: funcareakey,
url: url
var dataAdapter = new $.jqx.dataAdapter(source);$(“#listBoxA”).jqxListBox({ source: dataAdapter, displayMember: “ChannelName”, valueMember: “ChannelKey”, width: 200, height: 250 });
I am getting error on binding the source to the dataAdaptor , the error says – Uncaught TypeError: Cannot read property ‘dataAdapter’ of undefined
Although it is not hitting my action method. I dont know where i am doing wrong. And sorry as i was not getting the right place to post a new question.Hi Nishchaljain,
This means that you’re missing Javascript references to required Javascript files. I suggest you to look at the binding to json demo of our ListBox and se the list of references in the page’s head.
http://www.jqwidgets.comHi Peter , Thanks for a quick response.
I am using all the javascript files mention in the listbox tutorial.Below are the javascripts files that are on my page :
<link href=”~/jqwidgets/styles/jqx.base.css” rel=”stylesheet” />
<link href=”~/Content/bootstrap.min.css” rel=”stylesheet” />
<link href=”~/Content/toastr.css” rel=”stylesheet” /><link rel=”stylesheet” href=”//code.jquery.com/ui/1.11.4/themes/smoothness/jquery-ui.css”>
<script src=”//code.jquery.com/jquery-1.10.2.js”></script>
<script src=”~/Scripts/toastr.js”></script>
<script src=”~/Scripts/jquery.validate.min.js”></script>
<script src=”~/Scripts/jquery.validate.unobtrusive.min.js”></script>
<script src=”~/jqwidgets/jqxcore.js”></script>
<script src=”~/jqwidgets/jqxdata.js”></script>
<script src=”~/jqwidgets/jqxbuttons.js”></script>
<script src=”~/jqwidgets/jqxscrollbar.js”></script>
<script src=”~/jqwidgets/jqxlistbox.js”></script>Please let me know if i am still missing any.
Hi Nishchaljain,
Then the path to the files is incorrect.
