jQuery UI Widgets Forums Grid A problem about row details column
This topic contains 5 replies, has 2 voices, and was last updated by  debug 12 years ago.
  • A problem about row details column #21630
    debug
    Hello.
    I want to show row details when a row is clicked. I managed this by setting ‘rowdetails: true’ and setting ‘$(‘#jqxgrid’).on(‘rowselect’, function (event) { … });’ When I do this rowdetails column is also visible which I dont need in this case. So I set ‘showrowdetailscolumn: false’. But this makes filter box at first row invisible.
    Here is what I have so far.
                var initrowdetails = function (index, parentElement, gridElement, record) {
    var grid = $($(parentElement).children()[0]);
    detailsHtml =
    '<div style="width: 100%;height: 70px;float: left;margin-top: 20px">' +
    '<div style="width: 150px;height: 100%;float: left;margin-left: 10px">' +
    '<span style="width: 100%;height: 50%;float: left">Customer:</span>' +
    '<span style="width: 100%;height: 50%;float: left">{CustomerName1}</span>' +
    '</div>' +
    '<div style="width: 150px;height: 100%;float: left">' +
    '<span style="width: 100%;height: 50%;float: left">Porting Customer Id:</span>' +
    '<span style="width: 100%;height: 50%;float: left">{PortingCustomerId}</span>' +
    '</div>' +
    '<div style="width: 150px;height: 100%;float: left;margin-right: 200px">' +
    '<span style="width: 100%;height: 50%;float: left">Date Initiated:</span>' +
    '<span style="width: 100%;height: 50%;float: left">{CreationDate}</span>' +
    '</div>' +
    '<a href="#">Porting History</a> <a href="#">Edit</a>' +
    '<div style="width: 100%"></div>' +
    '</div>';
    detailsHtml = detailsHtml
    .replace('{MSISDN}', record.MSISDN)
    .replace('{MxneName}', record.MxneName)
    .replace('{ICCID}', record.ICCID)
    .replace('{CreationDate}', record.CreationDate)
    .replace('{TemporaryMSISDN}', record.TemporaryMSISDN)
    .replace('{CustomerName}', record.CustomerName)
    .replace('{CustomerName1}', record.CustomerName)
    .replace('{UserName}', record.UserName)
    .replace('{PortingCustomerId}', record.PortingCustomerId)
    .replace('{PxsStatusCode}', record.PxsStatusCode)
    .replace('{hid}', record.Id)
    .replace('{Id}', record.Id);
    // this part is out of case.
    var historybtn = $(detailsHtml).find("#show" + record.Id);
    if (historybtn) {
    var history = $(detailsHtml).find("#history" + record.Id);
    for (var i = 0; i &lt; record.PortInRequestAuditTrailList.length; i++) {
    var trail = record.PortInRequestAuditTrailList[i];
    $(history).append(&quot;<div style='width: 100%;height: 20px;float: left'>" + trail.ChangedBy + "");
    var parent = $(history).parent();
    var h = $(parent).height();
    $(history).css("height", (h + 20 * record.PortInRequestAuditTrailList.length) + "px");
    grid.html(detailsHtml);
    // initialize jqxGrid
    $("#jqxgrid").jqxGrid($.extend({ }, CommonGridOptions, {
    source: dataadapter,
    pagerrenderer: pagerrenderer,
    rowdetailstemplate: {
    rowdetails: "<div style='width: 100%;height: auto;background-color: #F5ECEE;float: left;padding-top: 5px'></div>",
    rowdetailsheight: 110,
    rowdetailshidden: true
    selectionmode: 'singlerow',
    rowdetails: true,
    //enablerowdetailsindent: false,
    showrowdetailscolumn: false,
    // fix for invisible right border when table is empty.
    _renderemptyrow: renderEmptyRow,
    rendergridrows: function () {
    for (var i = 0; i &lt; dataadapter.records.length; i++) {
    var record = dataadapter.records[i];
    record.PortingDate = new Date(parseInt(record.PortingDate.replace(/\/Date\((\d+)\)\//gi, &quot;$1&quot;)));
    record.ModificationDate = new Date(parseInt(record.ModificationDate.replace(/\/Date\((\d+)\)\//gi, &quot;$1&quot;)));
    record.CreationDate = new Date(parseInt(record.CreationDate.replace(/\/Date\((\d+)\)\//gi, &quot;$1&quot;)));
    return dataadapter.records;
    //{ text: 'User', datafield: 'asd', width: 10, columntype: 'textbox', filtertype: 'textbox', filtercondition: 'contains' },
    { text: 'User', datafield: 'UserName', width: 150, columntype: 'textbox', filtertype: 'textbox', filtercondition: 'contains' },
    { text: 'MSISDN', datafield: 'MSISDN', width: 150, columntype: 'textbox', filtertype: 'textbox', filtercondition: 'contains' },
    text: 'Network',
    datafield: 'MxneName',
    width: 150,
    filtertype: 'list',
    filteritems: [@Html.Raw(ViewBag.MxNEs)],
    createfilterwidget: function(column, columnElement, widget) { widget.jqxDropDownList({ dropDownWidth: ($('#hiddenSpan').width() + 30) }) }
    { text: 'Porting Date', datafield: 'PortingDate', width: 100, columntype: 'textbox', filterable: false, sortable: false },
    { text: 'Modified', datafield: 'ModificationDate', width: 100, columntype: 'textbox', filterable: false, sortable: false },
    { text: 'Temporary MSISDN', datafield: 'TemporaryMSISDN', width: 150, columntype: 'textbox', filtertype: 'textbox', filtercondition: 'contains' },
    { text: 'Status', datafield: 'PxsStatusCode', width: 110, filtertype: 'list', filteritems: ['CMP', 'CNC', 'BLC', 'AGR', 'RQS', 'HLD'] }
    $('#jqxgrid').on('rowselect', function (event) {
    var args = event.args;
    var index = args.rowindex;
    var details = $('#jqxgrid').jqxGrid('getrowdetails', index);
    var col = $('#jqxgrid').jqxGrid('getcolumnat', 0);
    $('#jqxgrid').jqxGrid('showrowdetails', index);
    $('#jqxgrid').on('rowexpand', function (event) {
    var details = args.details;
    var rows = $('#jqxgrid').jqxGrid('getrows');
    var row = rows[index];
    $(row).css(&quot;background-color&quot;, &quot;#F5ECEE&quot;);
    });</div>
    A problem about row details column #21646
    I cannot reproduce the reported behavior using jQWidgets 2.8.3. Filtering is also not enabled in the provided code.
    A problem about row details column #21649
    debug
    Thanks for reply. I am posting more detailed js. I am using jQWidgets v2.5.5 by the way.
    { name: 'Id'},
    { name: 'MSISDN' },
    { name: 'MxneName' },
    { name: 'ICCID' },
    { name: 'TemporaryMSISDN' },
    { name: 'PxsStatusCode' },
    { name: 'ProductId' },
    { name: 'XspName' },
    { name: 'CoinPortingId' },
    { name: 'PortingId' },
    { name: 'PortingCustomerId' },
    { name: 'Note' },
    { name: 'ChangeNote' },
    { name: 'PxsBlockingNote' },
    { name: 'PxsHoldNote' },
    { name: 'PxsNote' },
    { name: 'PxsPortingPerformedNote' },
    { name: 'RequestedDate' },
    { name: 'CreationDate' },
    { name: 'ChangeDate' },
    { name: 'ModificationDate' },
    { name: 'ActualPerformedDate' },
    { name: 'DonorNetworkOperatorId' },
    { name: 'DonorServiceProviderId' },
    { name: 'CustomerName' },
    { name: 'UserName' },
    { name: 'PortInRequestAuditTrailList' },
    { name: 'PortingDate' }
    root: 'Rows',
    url: 'NumberPortIn/GetPortInRequestsByXsp',
    sort: function () {
    $("#jqxgrid").jqxGrid('updatebounddata','sort');
    filter: function () {
    $("#jqxgrid").jqxGrid('updatebounddata','filter');
    source.totalrecords = data.TotalRows;
    var dataadapter = new $.jqx.dataAdapter(source);
    var detailsHtml = "";
    detailsHtml =
    '<div style="width: 100%; height: 100%; float: left;">' +
    '<div style="width: 150px; height: 30%; float: left; margin-left: 10px;">' +
    '<span style="width: 100%; height: 50%; float: left;">Customer:</span>' +
    '<span style="width: 100%; height: 50%; float: left;">{CustomerName1}</span>' +
    '</div>' +
    '<div style="width: 150px; height: 30%; float: left;">' +
    '<span style="width: 100%; height: 50%; float: left;">Porting Customer Id:</span>' +
    '<span style="width: 100%; height: 50%; float: left;">{PortingCustomerId}</span>' +
    '</div>' +
    '<div style="width: 150px; height: 30%; float: left; margin-right: 200px;">' +
    '<span style="width: 100%; height: 50%; float: left;">Date Initiated:</span>' +
    '<span style="width: 100%; height: 50%; float: left;">{CreationDate}</span>' +
    '</div>' +
    '<a href="#" id="show{hid}" class="btn" style="margin-top: 20px;">Porting History</a> <a href="#" class="btn" style="margin-top: 20px;">Edit</a>' +
    '<div id="history{Id}" style="display: none; width: 99%; overflow: auto; height: 66%; margin-left: 10px; width: 98%; float: left">{content}</div>' +
    '</div>';
    var historyContent = "";
    for (var i = 0; i < record.PortInRequestAuditTrailList.length; i++) {
    var changes = "";
    for (var j = 0; j < trail.Changes.length; j++) {
    var change = trail.Changes[j];
    changes += change.Target;
    if (j < trail.Changes.length - 1) {
    changes += ", ";
    historyContent +=
    "<div style='width: 100%; height: 20px; float: left;'>" +
    "<span style='font-weight: bold;'>Changed By: </span>" +
    "<span style='margin-right: 20px;'>" + trail.ChangedBy + "</span>" +
    "<span style='font-weight: bold;'>Date: </span>" +
    "<span style='margin-right: 20px;'>" + getDateFromJson(trail.Date) + "</span>" +
    "<span style='font-weight: bold;'>Changes: </span>" +
    "<span style='margin-right: 20px;'>" + changes + "</span>" +
    "</div>";
    .replace('{CreationDate}', getDateFromJson(record.CreationDate))
    .replace('{content}', historyContent);
    if (historybtn) {
    $(historybtn).click(function (event) {
    event.preventDefault();
    $("#history" + record.Id).slideToggle();
    function getDateFromJson(jsonDate) {
    try {
    var date = eval(jsonDate.replace(/\/Date\((\d+)\)\//gi, "new Date($1)"));
    return date.format('dd-mm-yyyy');
    } catch (ex) {
    return '';
    $("#jqxgrid").jqxGrid({
    width: 912,
    rowsheight: 31,
    filterrowheight: 31,
    pagerheight: 32,
    theme: 'firmtel',
    pagesize: 10,
    pagesizeoptions: ['10', '20', '50', '100'],
    virtualmode: true,
    autoheight: false,
    columnsresize: false,
    showfilterrow: true,
    selectionmode: "multiplerowsextended",
    showdefaultloadelement: true,
    rowdetails: "<div style='width: 100%; height: 98%; background-color: #F5ECEE; float: left; padding-top: 5px;'></div>",
    rowdetailsheight: 150,
    rowdetails: true,
    for (var i = 0; i < dataadapter.records.length; i++) {
    record.PortingDate = getDateFromJson(record.PortingDate);
    record.ModificationDate = getDateFromJson(record.ModificationDate);
    record.CreationDate = getDateFromJson(record.CreationDate);
    text: 'Network',
    width: 150,
    filtertype: 'list',
    $('#jqxgrid').on('rowunselect', function (event) {
    $('#jqxgrid').jqxGrid('hiderowdetails', index);
    $('#jqxgrid').on('rowunexpand', function (event) {
    $(row).css("background-color", "#F5ECEE");
    A problem about row details column #21651
    debug
    I tried with latest version jQWidgets v2.8.3. but result was same.
    A problem about row details column #21652
    Thanks for the updating the code snippet. I tried it and reproduce the issue. I also created a work item about it. A fix will be provided in the next release.
    A problem about row details column #21655
    debug
    Thank you Peter.
    I made a workaround. I added additional column before 1rst column. then I hide it. now problem with invisible filter box solved. It will be better if you fix this on next release.
    But will you please tell me if I can achieve what I am trying to do or not? Let me repeat my goal.
    I want to expand row details by clicking row itself. How can I do it?
    I am using rowselect and rowexpand events right now. With this way I am producing row details but they are not positioned under the selected row. they are somewhere above the grid because of wrong left and top properties of the css.
    $(details).css("left", "0").css("top", "32px");
