This topic contains 3 replies, has 2 voices, and was last updated by  Hristo 9 years, 3 months ago.
  • Window display issue #91030
    Pfhoenix
    I’ve discovered some odd behavior involving windows opening windows. It seems that if a non-modal window opens up a modal window inside it (defined within its content space), the new modal window appears behind the non-modal window, regardless of zIndex setup.
    This jsfiddle lets you play around with what I’m describing.
    http://jsfiddle.net/du7Kd/59/
    Is this intended behavior? I would expect any window opened by another window to appear on top of it, and I would expect modal windows to be on top of all other windows, in the order they’re opened.
    Window display issue #91055
    Hello Pfhoenix,
    You could try with the bigger difference in the “zIndex”.
    Window display issue #91118
    Pfhoenix
    Thanks, that does seem to work. Any idea why the larger zIndex separation is necessary?
    Window display issue #91160
    Hello Pfhoenix,
    We will investigate this.
    I would suggest you use without zIndex or just set some sensitive bigger value for this property.
    Also, because each window is separated could be created out of the other windows and out of the initContent.
    http://jsfiddle.net/36oa3bvy/
    Thank you for your understanding.
