jQuery UI Widgets Forums General Discussions Editors Calendar titleFormat does not work as expected
This topic contains 2 replies, has 2 voices, and was last updated by  Hop 12 years, 3 months ago.
  • titleFormat does not work as expected #45691
    Hop
    I went to the API for the jqxCalendar and expanded the titleFormat property. I copied the example (titleFormat portion) and added it to my code. I expected to see the same results as the default for this property, but instead, I got the full month name followed by today’s day date. IE: “November 30”. I tried other combinations used in the expanded info under the property in the API and got back a blank line and loss of control moving forward and back through the months.
    Here is what I have for initializing the calendar widget.
    $("#"+record.name).jqxCalendar({titleFormat: "MMMM yyyy", showWeekNumbers: true, enableWeekend: true, navigationDelay:200, width: 500, height:500});
    I am trying to change the title to a format “yyyy-MM-dd”. That’s when the title went blank and I lost calendar navigation control.
    Thank you for your time!
    titleFormat does not work as expected #45702
    Hi Hop,
    The property should be set to an array of formats.
    Ex: [“MMMM yyyy”, “yyyy”, “yyyy”, “yyyy”]
    titleFormat does not work as expected #45720
    Hop
    Ok Peter, thank you. That fixed it. But I still do not know why. The example doesn’t show your solution so I do not know what the elements in the array refer to. I just changed the first element to be “yyyy-MM-dd” and left the other three elements the same as you shown in your example.
    $("#"+record.name).jqxCalendar({ titleFormat: ["yyyy-MM-dd", "yyyy", "yyyy", "yyyy"], showWeekNumbers: true, enableWeekend: true, navigationDelay:200, width: 500, height:500});
    That gives me what I wanted though. My curiosity is all I need solved at this point.
    Thank you for your time and reply!
