jQuery UI Widgets Forums General Discussions Lists DropDownList RTL issue with FILTERING
This topic contains 1 reply, has 2 voices, and was last updated by  ivailo 11 years, 1 month ago.
  • RTL issue with FILTERING #74735
    JOsh777
    Hello.
    I have the following issue,
    I needed to enable the FILTER option with the RTL option. The result was that all of the elements on the screen were RTL, except from the FILTER element itself, which remaind LTR (thus hidden by the scrollbar).
    After fiddling around with the development tools, I found that the FILTER element as well as its direct parent always get the inline css attribute “left: _px” regardless of the DIR (in RTL I would expect it to receive “right: _px”).
    Here is some sample code that reproduces the problem.
    Sincerely,
    Josh
    RTL issue with FILTERING #74743
    ivailo
    Hi Josh,
    We will investigate the problem.
    Here is a simple workaround to fix it.
    Ivailo Ivanov
