jQuery UI Widgets › Forums › Grid › Paging 'footer' flushed to top and hidden behind grid
This topic contains 5 replies, has 2 voices, and was last updated by  sjkcwatson 11 years, 11 months ago.
  • sjkcwatson
    I’ve tried copying and pasting to see what I’m missing. My grid is bound to json data and working correctly, however when I turn on the paging, the “row” that contains the page controls is flushed to the top and hidden behind my grid. If I resize my grid columns to very small I can see it behind and use them. I’m hoping someone can tell me what I am missing.
    <%@ Page Language=”vb” runat=”server” AutoEventWireup=”false” CodeBehind=”test_translations.aspx.vb” AspCompat=”true” ValidateRequest=”true” %>
    <!–#include file=”include_declarations.inc”–>
    <% Dim ShowType As String%>
    Session(“sysmsg”) = “ORIAS”
    Session(“sysmsg2”) = “back somewhere”
    <!–#include file=”dbConnNet.inc”–>
    <!–#include file=”maintenance\check_userNet.asp”–>
    <html xmlns=”http://www.w3.org/1999/xhtml”>
    <head id=”Head1″ runat=”server”>
    <title>ORIAS</title>
    <link href=”css/css_main.css” rel=”stylesheet” type=”text/css” />
    <link href=”css/css_print.css” rel=”stylesheet” type=”text/css” media=”print” />
    <body>
    <link rel=”stylesheet” href=”javascript/jqwidgets/styles/jqx.base.css” type=”text/css” />
    <link rel=”stylesheet” href=”javascript/jqwidgets/styles/jqx.base.css” />
    <link rel=”stylesheet” href=”javascript/jqwidgets/styles/jqx_oriasmenu.css” type=”text/css” />
    <link rel=”stylesheet” href=”javascript/jqwidgets/styles/jqx.energyblue.css” type=”text/css” />
    <script type=”text/javascript” src=”javascript/jquery-1.10.2.min.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxcore.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxmenu.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxdata.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxbuttons.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxscrollbar.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxcheckbox.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxlistbox.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxdropdownlist.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxdropdownbutton.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxcalendar.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxnumberinput.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxdatetimeinput.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.pager.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.filter.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.sort.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.columnsresize.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.selection.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxgrid.edit.js”></script>
    <script type=”text/javascript” src=”javascript/jqwidgets/jqxpanel.js”></script>
    var THEMESETTING = { theme: “oriasblue” },
    url = “WebServices/OriasWcfService.svc/GetTranslationList”,
    gridData, gridDataAdapter, gridSource, id, result, rowindex, key, rowId, themeSource,
    gridRowCount, index, item, label, value, mainGridDetail, container;
    // define source for main grid
    gridSource = {
    { name: ‘TransID’, type: ‘integer’ },
    { name: ‘English’, type: ‘string’ },
    { name: ‘Dutch’, type: ‘string’ },
    { name: ‘Portuguese’, type: ‘string’ },
    cache: false,
    url: url,
    async: false,
    gridDataAdapter = new $.jqx.dataAdapter(gridSource, {
    autoBind: true,
    downloadComplete: function (data) {
    return data.d;
    loadError: function (status, error) {
    alert(“An error occurred with the jqxDataAdapter: ” + String(error) + “.\nThe status is currently: ” + String(status));
    var imagerenderer = function (row, datafield, value) { return ‘‘; }
    gridRowCount = gridDataAdapter.records;
    $(“#jpxgridDutch”).jqxGrid({
    width: ‘95%’,
    source: gridDataAdapter,
    selectionmode: ‘multiplerowsextended’,
    pagermode: ‘simple’,
    { text: ‘ID’, dataField: ‘TransID’, width: ‘5%’, cellsalign: ‘left’, align: ‘left’ },
    { text: ‘English’, dataField: ‘English’, width: ‘45%’, cellsalign: ‘left’, align: ‘left’ },
    { text: ‘Dutch’, dataField: ‘Dutch’, width: ‘45%’, cellsalign: ‘left’, align: ‘left’ },
    $(“#jpxgridDutch”).jqxGrid(THEMESETTING);
    <div id=’jqxWidget’ style=”font-size: 13px; font-family: Verdana;”>
    <script type=”text/javascript” src=”javascript/sysadm_translations_dutch.js”></script>
    <div id=”jpxgridDutch”></div>
    sjkcwatson
    The <xcript … sysadm_translations_dutch.js … > should be removed. The code was dropped above in the javascript to simplify. Same issue.
    Hello sjkcwatson,
    Please make sure you are using the latest version of jQWidgets (3.5.0) and remove one of the references to jqx.base.css in your code. If these suggestions do not help you fix the issue, please share if the issue occurs only when a theme is applied to your grid.
    sjkcwatson
    It is the theme that is causing it. If I take the theme off it is fine.
    Hi sjkcwatson,
    If you move the theme setting to the initialization part of the grid, the issue should be gone, i.e.:
    theme: “oriasblue”,
    width: ’95%’,
    { text: 'ID', dataField: 'TransID', width: '5%', cellsalign: 'left', align: 'left' },
    { text: 'English', dataField: 'English', width: '45%', cellsalign: 'left', align: 'left' },
    { text: 'Dutch', dataField: 'Dutch', width: '45%', cellsalign: 'left', align: 'left' },
    Remember to also remove the line:
    sjkcwatson
    Yes it did! Thank you very much for your help!
