jQuery UI Widgets › Forums › General Discussions › Navigation › Tree › jqxtree add icon for nodes and subnodes (load on demand)
This topic contains 2 replies, has 2 voices, and was last updated by kamran 12 years, 11 months ago.
Hello there,
How can I add icons for the jqxtree nodes and sub nodes when using load on demand version?
Hello kamran,
Please take a look at the following example:
<!DOCTYPE html><html lang="en"><head> <title id='Description'>This sample demonstrates how to load Tree Items via Ajax </title> <link rel="stylesheet" href="../../jqwidgets/styles/jqx.base.css" type="text/css" /> <script type="text/javascript" src="../../scripts/gettheme.js"></script> <script type="text/javascript" src="../../scripts/jquery-1.8.3.min.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxcore.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxbuttons.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxscrollbar.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxpanel.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxtree.js"></script> <script type="text/javascript" src="../../jqwidgets/jqxexpander.js"></script> <script type="text/javascript"> $(document).ready(function () { var theme = getDemoTheme(); // Create jqxTree var tree = $('#jqxTree'); var source = [{ label: "Root", expanded: true, items: [ { label: "Root Folder 1", items: [{ value: "ajax1.htm", label: 'Loading...' }] }, { label: "Root Folder 2", items: [{ value: "ajax2.htm", label: 'Loading...' }] } ] }]; tree.jqxTree({ source: source, theme: theme, height: 300, width: 200 }); tree.bind('expand', function (event) { var label = tree.jqxTree('getItem', event.args.element).label; var $element = $(event.args.element); var loader = false; var loaderItem = null; var children = $element.find('ul:first').children(); $.each(children, function () { var item = tree.jqxTree('getItem', this); if (item && item.label == 'Loading...') { loaderItem = item; loader = true; return false }; }); if (loader) { $.ajax({ url: loaderItem.value, success: function (data, status, xhr) { var items = jQuery.parseJSON(data); tree.jqxTree('addTo', items, $element[0]); tree.jqxTree('removeItem', loaderItem.element); } }); } }); }); </script></head><body class='default'> <div id="jqxTree"> </div></body></html>
with the files:
ajax1.htm:
[{ "label": "Folder 1", "items": [{ "value": "ajax.htm", "label" : "Loading..." } ] },{ "label": "Folder 2", "items": [{ "value": "ajax.htm", "label" : "Loading..." } ] },{ "label": "Folder 3", "items": [{ "value": "ajax.htm", "label" : "Loading..." } ] }]ajax2.htm:
[{"label": "Folder 5" },{"label": "Folder 6" },{"label": "Folder 7" },{"label": "Folder 8" }]and ajax.htm:
[{"label": "Folder 9" },{"label": "Folder 10" },{"label": "Folder 11" },{"label": "Folder 12" }]You may modify one of them (e.g. ajax1.htm:) in the following way to add an icon:
[{ "icon": "http://www.jqwidgets.com/jquery-widgets-demo/images/tree.png", "label": "Folder 1", "items": [{ "value": "ajax.htm", "label" : "Loading..." } ] },{ "label": "Folder 2", "items": [{ "value": "ajax.htm", "label" : "Loading..." } ] },{ "label": "Folder 3", "items": [{ "value": "ajax.htm", "label" : "Loading..." } ] }]Best Regards,
http://www.jqwidgets.com/thanks that helps
