jQuery UI Widgets Forums Scheduler I’m stuck on a problem involving: Scheduler. Any suggestions?
This topic contains 1 reply, has 2 voices, and was last updated by  admin 10 months, 1 week ago.
  • jovanovic
    How do I block certain hours in the jqxScheduler week view using jQuery? I don’t want users to book between 12am and 6am.
    admin
    jqxScheduler lets you “block” hours (so users cannot create appointments in those ranges) using the resources, editDialogCreate, or more directly with the appointments source + appointments rendering.
    But the cleanest way to block time ranges in jQuery is with the renderAppointment + cellDoubleClick (or appointmentAdd) event combination, where you:
    Catch when the user tries to add a new appointment.
    Check if the time falls within the “blocked” window (12 am – 6 am).
    Cancel or show a message.
    <div id="scheduler"></div>
    <script>
        let appointments = [];
        let source = {
            dataType: "array",
            dataFields: [
                { name: 'id', type: 'string' },
                { name: 'description', type: 'string' },
                { name: 'location', type: 'string' },
                { name: 'subject', type: 'string' },
                { name: 'calendar', type: 'string' },
                { name: 'start', type: 'date' },
                { name: 'end', type: 'date' }
            localData: appointments
        let adapter = new $.jqx.dataAdapter(source);
        $("#scheduler").jqxScheduler({
            date: new $.jqx.date(2025, 9, 4),
            width: 850,
            height: 600,
            source: adapter,
            view: "weekView",
            showLegend: true,
            views: ["dayView", "weekView", "monthView"],
            appointmentDataFields: {
                to: "end",
                description: "description",
                subject: "subject",
                resourceId: "calendar"
        // Prevent booking in blocked hours
        $("#scheduler").on('appointmentAdd', function (event) {
            let args = event.args.appointment;
            let startHour = args.from.getHours();
            let endHour = args.to.getHours();
            if (startHour < 6) {
                alert("Booking between 12am and 6am is not allowed.");
                event.cancel = true; // block appointment creation
        // Optional: prevent double-click new appointment creation
        $("#scheduler").on('cellDoubleClick', function (event) {
            let clickedHour = event.args.date.getHours();
            if (clickedHour < 6) {
                alert("This time slot is blocked.");
    https://www.jqwidgets.com/
